1 - 20 of 150 Posts
Image: motawa10.com
http://www.coolermaster.eu/Eisberg/
The Eisberg Prestige is the new benchmark when it comes to CPU cooling. All metal parts of the in Germany designed Eisberg are made of pure copper and with the newly developed Jet Stream Technology it provides the best heat dissipation from the cooling-head to the radiator. The Eisberg Prestige 120 is a perfectly balanced water cooler, which can be mounted like a standard air cooler. The 240-version offers even more cooling performance because of the bigger radiator. Of particular interest to everybody who already has a water cooling system and is looking to complement their system is the Eisberg Prestige Single. The Single is ideally suited as well to develop a new efficient water cooling system with other components. All Eisberg versions will be pre-filled, sealed and tested in Germany to ensure durability and performance when the pump is installed.
With tech prices, € --> $ tends to be around 1:1 and is not based on direct currency conversion.
Cooler Master Eisberg Prestige Solo - 99,90€ (aka Eisberg Prestige Single)
Cooler Master Eisberg Prestige 120L - 139,90€
Cooler Master Eisberg Prestige 240L - 159,90€
Full info thread - Cooler Master Eisberg 120, Eisberg 240, and Eisberg 360 Water Cooling Solutions
Cowcotland - [Cowcot TV] Présentation Cooler Master Watercooling AIO Eisberg
Originally Posted by SammichThyme View Post
The best I saw was 4 degrees cooler than an H100, unfortunately I have lost interest. The loud pump also does it for me.
Are you kidding me? Four degrees is huge! Not sure what you expected.
I am only really interested in the larger one, as it is the biggest advancement in sealed loop cooling aability in a very long time. While I have no interest in these kinds of units for myself iit's about time for a change.
⤷ αC
Hope this is so, because if it is converted it's pretty pricey... we're looking at prices close to XSPC kits!
Cooler Master Eisberg Prestige Solo - 99,90€ --> 130 USD?
Cooler Master Eisberg Prestige 120L - 139,90€ --> 181 USD
Cooler Master Eisberg Prestige 240L - 159,90€ --> 207 USD
RPG Gamer
4 degrees is big. You can change the rad to a triple if you want, and get better temps. The H100 is very limited with its aluminum rad, as it can only dissipate so much heat.
Copper can still do more, even when you start adding more fans in a P/P.
You are not stuck with what you have. Realize that the Eisberg if fully customizable, H100 is not.
Watercooled Railgun
Wow, does not look bad at all. If the pump is as noisy (or less) as my DDC-1T, i might be sold on one for a project i have.
Turtle Lives Matter
HAIL EISBERG!
Reactions: chmodlabs
This really isn't a sealed loop though. It's prefilled and fully assembled out of the factory, but it is also easily taken apart and fully customizable. This is nowhere near the same as a H100, it's similar to the Swiftech H20 kits and XSPC kits, except it comes fully ready to go instead of assembly required.
I am a custom loop kind of guy and was expecting something approaching custom loop temps.
I'm pretty sure that the difference between this unit and a comparable custom unit is smaller than the difference between this unit and the H100.
Turtle Lives Matter
I bet if you drain the EISBERG, flush it out, and refill it with pure water then temps would improve. I'm sure they are filled with some anti-corrosion biocide. Adding a reservoir would help too, and you can do all of this under warranty, which is nice.
Dont forget that all EU prices include VAT. So it usually is 1usd (without tax) = 1 eur (with tax)
Initializing...
My next cooler for sure, sure as hell will be better than the H100.
I need to know the OEM
Eg1: The eisburg
Eg2: The PHOBYA CPU COOLER UC-1 LT
It isn't a sealed loop, if it where it wouldn't have a fill hole.
1 - 20 of 150 Posts
