Gonna try out one of my tecs and wondering if vasoline will work the same? I use it on my car battery terminals so just curious.
How about the socket, I guess you cannot apply liquid electrical taper there. Still Vaseline(dielectric grease)?
Yah... It's kinda needed... I like to use let on the board and I use die electric grease since I have a lot of it... Vasaline will work just fine though
As long as it works
Pipe it into the socket and then press ur CPU inOriginally Posted by foxrena
As long as it worksI guess it is not intended for 24/7.![]()
When I apply the dielectric grease/Vaseline, should I just put a film on the bottom of the CPU, then drop it into the socket?
I think this may be the correct approach since the CPU bottom is flat and pins are so fragile.
How do you guys do it?
Syringe is it ? Will it be to much?
