1 - 20 of 246 Posts
The benchmarks come from Coolenjoy, where we learn that the CPU was tested on ASUS APEX motherboard (designed for overclockers). What was discovered is that the CPU boosts up to 4.2 GHz on all cores during Cinebench. It's unclear if this is a motherboard-specific feature or this is exactly how it's supposed to be. Officially the i9-7980X should only boost up to 4.4 GHz on two cores in Turbo Boost Max 3.0 and up to 4.2 GHz in Turbo Max 2.0.
Source: https://videocardz.com/72680/intel-core-i9-7980xe-early-benchmarks
High Clocker
4.2ghz is benchmark boost on all cores that iv been reading about in the leaks so far.
So we know it should overclock to that much on all cores atleast.
Top kek
Doesn't sound right. More likely a software reading bug.
Robotic Chemist
It is a pretty high TDP, 165W. I wouldn't be surprised if the "stock" all core boost was 4.2GHz on the Apex.
FOCAL ARIA FTW
I wonder what Silicon Lottery will charge for a chip like this clocking close to 5 GHz
Soo its look good: hard overclocked 1950x cca 4300 p. in cinebench. and this unitel 18 core show 4200 on 4,200mhz.. maybe 4500-5000 points on cinebench with happy gold sillicone:rolleyes:
1000+ point more with 1000usd more:D:D ... but all this setup need and will need loudy aio water cooling(150usd) or custom expensive water cooling 500usd more
just imagine how many watts when you will run wcg or boinc/folding avx, .. its like big radiator in your room , or you need aircon
Clearly thats the intent there. You pay 1USD per cinebench point :-D
It will no doubt OC to 4,2GHz on all cores without any issues. Except at those clocks the power consumption will be perhaps on par with 12core clocked to 4,6.
We shall see... Bring on Monday. I cant wait to lay my filthy hands on some shiny 7940x:D
Top kek
I cant wait to see the effects on the ozone this will have at 4+ghz. Or on the global warming.
Originally Posted by Asterox View Post
Core i9-7980XE is classic Intel overpriced CPU garbage no doubt.
If someone needs that level of Multithreading CPU performanse, well AMD Epyc 7401P is only logical choise.
- Epyc 7401P 24/48 /2.8ghz TurboCore all cores,128 PCIE lanes, Cinebench R15 Multithread 4200,1075$
http://www.cpu-world.com/CPUs/Zen/AMD-EPYC%207401P.html
- single slot SP3 motherboard
https://hothardware.com/news/gigabyte-mz31-amd-epyc-7000-motherboard-16-dimm-slots
Except for those of us who still need decent single threaded performance the 7980XE etc... are far superior to EPYC or Threadripper because you're looking at 2.8ghz Haswell IPC levels (i'm guessing ~150 cinebench single thread score? Around the same as the stock 3ghz i7 5960X.) with EPYC (not to mention you're limited to server mobo choices and ECC memory for the most part. Or if you go for Threadripper instead to fix that problem you're still only at ~3.9ghz Broadwell level at best since finding an 1950X that clocks higher the 3.9 is like getting mauled by a Unicorn lol. Meaning you're still looking at roughly stock speed Broadwell IPC ~165 point Cinebench single thread score etc...
Meanwhile benchmarks of the 7980XE show it getting roughly 200 points in single thread Cinebench 15 just with standard stock turbo boost where it boosts like ~6-8 cores to 4.2ghz-ish or whatever and leaves the rest in the 2.6 to 3-something range. I saw another benchmark of a 7980XE with all cores pushed to 4.7ghz with pretty high voltage and high end water loop and it got 206 point single thread R15 result iirc. That's nothing to scoff at frankly.
And this isn't even mentioning that 4,200 for a 24 core EPYC still is quite a bit lower than the 4,700+ that 18 core 7980XE is getting with a proper overclock put on it. Plus if 24 core EPYC is only ~1,000 points over 12 core 1920X Threadripper then i wonder if even the 32 core EPYC can reach ~5,000 or not.
Problem is that 7980XE can do everything great while AMD's HEDT is only good at one area. Then you get apologists screaming "HEDT is not for gaming" thus accepting that Threadripper is a one trick pony.
I guess we can call the first Core i7 processors a one trick pony. The architecture needed time to mature. Zen's SMT just needs time to mature just like the first Core i7's hyper threading. The difference is it cost $1000 more for 2 more cores. That $1000 can be put toward 1 or 2 high-end video cards. ThreadRipper has Broadwell IPC and sometimes faster in professional applications.
Comparing the first generation Core i7 processors. The Core i7 930 was getting whooped by the Core i5 2500k. Now it's on par or faster at stock
https://www.anandtech.com/show/4083/the-sandy-bridge-review-intel-core-i7-2600k-i5-2500k-core-i3-2100-tested/20
Sorry I don't want Ivy Bridge-Haswell level IPC in 2017.
More Vcore
Originally Posted by Le*****James View Post
Dude even AMD disagrees with you. HEDT is for gaming, content creation and pretty much everything a client PC is expected to do:
http://www.amd.com/en/products/ryzen-threadripper
Did you really just link a companies marketing to back up your point? Bad form
You can game on anything. Nobody is saying you can't. It is up to the consumer to pick the CPU that will best compliment their usage. I game 80% of the time I am at my computer with my 6950X. That other 20% is video encoding though, and I put more weight on my encoding times than I do the extra FPS a 7700k would of brought me.
18 x 4200mhz + 4000C17 > 24 x 2800mhz + 2667C17 by ~40-45%... ( higher IPC )
Apparently 3400-3600mhz ( at 1.40v ) on the NB Clock for Skylake-X is possible on water.
1 - 20 of 246 Posts
