1 - 20 of 62 Posts
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 90
MSI decided to quietly launch its GAMING edition of Radeon R9 280X altogether with the R9 280.
The 6GB variant of R9 280X GAMING is clocked at 1000/1050 MHz with a memory at 6GHz. Card is equipped with 6GB GDDR5 memory and 384-bit interface.
Source
Software Developer
Originally Posted by DizZz View Post
Why do you need 6gb of VRAM on a 280x...
The card isn't powerful enough to push multi-monitor setups or a 4k display so I don't understand this decision. Wouldn't putting 6gb of memory on a 290 or 290x make more sense?
I want the one with the bigger GBs.
Reference: http://www.youtube.com/watch?v=FL7yD-0pqZg
Software Developer
Originally Posted by wstanci3 View Post
Sorry, MSI simply not enough.
I am trying to push 1080p on COD Ghosts and 6gb simply won't cut it.
At least Sapphire has the sense to make a 290x with 8gb...
I hope this is sarcasm. With eyes rolling.
CoD Ghosts barely uses 1.15GB of VRAM at 1080 about 1500MB for 2560x1600 and max settings.
So there is something seriously wrong with your system if you are not sarcastic.
Originally Posted by <({D34TH})> View Post
Sounds more like the game's fault than the card's..
I was being very sarcastic.
This card with 6Gb is not remotely sensical unless you are using it for 2D/3D rendering, modeling etc. and even then...
It's Riley. He's the Vram hog.
⤷ αC
Stock
I don't see the big deal you guys remember the Sapphire 7970 Toxic and Vapor-X @ 6GB..... Those had rave reviews and some of you guys were salivating over them.... MSi was a little late with the bazooka
And yes I have yet to see a game maximize the video ram, but hey! there's a market for this card for some one
So basically epeen
the 770 and 760 had a similar bump from 2GB to 4GB with the MSI cards
Is the RAM increase really needed? I am sure somewhere I seen that the cards don't actually use the extra RAM.
I thought that it would be 2GB or less was needed for games.
Aren't this fancy!
Originally Posted by whtchocla7e View Post
4k textures in Skyrim, here I come.
To bad Skyrim's limit is somewhere in the 2.7gb vram range. Beyond that many people face game instability... unless something has changed in the last few months.
What causes this limit? With ENBoost and Sheson's Memory Patch Skyrim people can run ugrids 19 (count em!) and I've personally reached 2.9GB in Wyrmstooth without instability.
But I can't think of games apart from modded skyrim/hitman which could possibly use over 3GB, and as others have said for multi-monitor you'll be picking bigger and better cards.
1 - 20 of 62 Posts
