1 - 20 of 22 Posts
ok when im running at load i experience a small amount of vcore droop but how come when i turn off all processes and become idle my vcore increase past what i set in bios? Is this normal? all my other voltages don't fluxuate much at all <3% or so.
also whats the higest vcore i should run my Northwood at?
I'm pretty sure that 1.525 is the max. +-3% is pretty standard for any PSU. Everything except the PC Power and Cooling Turbo Cool 510 which is +-1%. What is your amperage rating on the 12v rail?? If you are at anything less than 25Amps, that could be your reason for the Votlage drops.
1.525 there isnt even an option in bios for me to set my vcore that low remember i have a northwood not a prescott.
Northwoods run 1.5, Prescotts run around 1.4, and willamettes run 1.7, you sure you don't have a willamete?
And I think NoAffin says 1.6-1.65 is max for Northwood, they seem to die suddnely.
Discussion Starter · #8 ·
no im sure i have a northwood i specifically asked for a northwood when i bought it and CPU-Z says its a nortwood. I have the vcore set to 1.575 and when its idle sometimes it reaches 1.62 or so is that really bad?
should i trust CPU-Z's vcore readouts?
There's also that thing with ASUS and vcore drooping. CPU-Z isn't the most accurate, but then again nothing is. Probably want to wait 'til the Intel gurus show up though.
Discussion Starter · #12 ·
ok well if i check the voltages while in bios they hardly fluctuate much at all. what are the effects if my vcore increases to far is it heat issues or will it mysteriously kill my processor? Also MBM5 doesnt show it fluctuating quite as far.
Hmmm... CPU-Z sometimes shows my core voltage drop to .9 volts from 1.75, and I would think such a drop at 2200MHz would cause the system to hange or reboot, it could just be CPU-Z being weird. Northwoods die with too much voltage and/or heat, it's called Sudden Northwood Death Syndrome because they'll look like they're running strong and then just quit one day. Best is to keep loads below 50C and voltages as low as possible.
yeah, have you got the latest bios update? if you don't consider updating it, because that could be teh result of faulty readouts. also, how many different monitoring software systems do you have installed on your rig?
Discussion Starter · #15 ·
ok so even at stock voltages when the cpu is idle my vcore readouts on mbm5 CPU-Z and speedfan all read around 1.62v for some reason.
what might be causing this and are there any inexpensive ways to fix it?
what exact model is your PSU?
hmm...20 amps might not be cutting it. i haven't heard of that company, so if anyone has, which i'm sure of, just chime in. 20 amps on teh 12 rail is really low, so you might wanna unplug any unnecessary system fans, etc. to give more power to the CPU.
Discussion Starter · #19 ·
im confused why should it be supply more volts that it should be if im drawing too much power? that doesnt make any sense i would think in would droop down and undervolt not overvolt my processor.
Discussion Starter · #20 ·
also it seems to do fine (a little droop but not much) as long as i keep some sort of load on it like folding.
1 - 20 of 22 Posts
