1 - 7 of 7 Posts
[Wed Oct 25 20:10:53 2006]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
[Wed Oct 25 20:12:26 2006]
http://valid.x86-secret.com/show_oc?id=132880
What seems to be the problem???
Thanks in advance.
http://i28.photobucket.com/albums/c2...emory-2540.jpg
http://i28.photobucket.com/albums/c2...k/spd-2540.jpg
Hmmm whats your voltage at? Should be around 1.5v What is your HT at? Should be at 3-4x
You can tighten your ram timings a little bit btw
try 2.5 3 3 7
Push your vcore up a notch and you should be all set
What is your RAM divider set at? You are losing a lot of performance by running your RAM that slow. You could probably set the divider up to the next fastest divider.
Sorry for being late to the party, but if you are still up playing. That 317 FSB is pretty aggressive for a 3500+ try dropping it down and upping the multiplier. Right now I am running at 250 with a multi of 10.5 for a core speed of 2.6. If you are stable at that point, try dropping your command rate from 2 to 1t for another pop. Also, I agree with the earlier comment about your divider being too severe.
.5 multi's eff w/ your FSB overall speeds..... 317 ain't a thing for the 3500. i was running 325 x 8 so i could get my overall fsb speeds up.... bump your voltage up on your chipset, and your ram to try to stable it out, just keep watch on your temps.
Discussion Starter #7
RAM divider is 100. Then its 158(2).
I will up chipset voltage to max.
I will tighten timings.
Yeah, it's 3x.
I just added like 3 fans to my case
Sadly, my board only has hammer CPU multi like this: 11x, 10x, and so on until 6x. No .5 numbers.
1 - 7 of 7 Posts
