1 - 12 of 12 Posts
I just built my new loop, loop consides of:
XPXC Dual Res with Laing DDC Pump
HWL GTX240
Swiftech Apogee XT
EK Multi Option Res
GTX470
GTX470 (connected via an EK SLI Bridge)
HWL GTX360
I have a 2nd res as i needed a way to fill the loop, (cant use the dual bay res filling port)
Problem i have is I have EXTREMLY low flow rate,
http://imageshack.us/photo/my-images/35/img2461j.jpg/
That air bubble between the CPU and the Cylinder Res is just sitting thier, I also cant feel much flow in the pipes (from touch).
I have no idea what is wrong here,
Anyone ?
Storage Nut
Originally Posted by andrewmchugh
MAN... lol. that res in the center has broken your loop.
remove it.
Who told you do put a res there?!
That^ you shouldn't set it up that way...
Discussion Starter · #8 ·
The top of that cylinder res has 2 verticel pipes going down, way below the water level,
I didnt plan on 2 res, just couldnt use the bay res fill port as it cant be pulled out due to a pipe connecting that directly to the 240.
Needed someone of getting water into the system. Only issue was getting water to the bay res.
Originally Posted by Cygone
Resevoires dont break loops, they are a closed system, as long as the inlet the outlet are both under water
look at the pic there not under the water there above
1 - 12 of 12 Posts
