Where price is not a issue which would you say is a very good if not the best 140mm fan for a radiator with a high fin count (16 - 20 fins)
I just ordered some 2000 and 3000 rpm Noctuas myself to test them out. Both have pretty high static pressure. They are loud at full throttle but with PWM will run quiet. The EK Varder are good in the 140mm size as well.
PH-F140MP is a good fan for case, cooler and radiator applications.
