1 - 3 of 3 Posts
I Am Gooble Gobble
ok so this card has been used constantly for minimal tasks on a spare pc, all of a sudden yesterday, under load or idle, around every 5 minute the monitor on the HDMI out goes black, but the DVI/DP monitors are fine. ive changed hdmi cables, got the same, threw a 270x off my coin rig in for a test, issue goes away. very odd, i know the card can be dying, its never seen an overclock or over 40c, and its being run on an HX850
any ideas of the cause guys?
Might be a dying port? I would try the card in another PC and see if the problem persists. If it does, RMA it.
I had a similar issue, but for only about half a day.
Screen cut out.... got black nothingness "no signal" message.
Later that day my PSU made a horrible noise/smell shut it down to check it out... never worked again.
Probably not what you want to hear but that was my experience.
1 - 3 of 3 Posts
