You can see my specs. I updated my Bios, things got screwed up, got a brand new board from ASUS. Problem Started. Installed Half Life. Freezes 2 minutes in. Every Time I run it. Apparitions appear in Doom 2 and freezes occasionally. Older games run fine.
Thought it could be a bad install. Uninstalled and reinstalled several times. No good.
Overclocked too much? Took it all the way back to factory. Slightly longer play time before freezing.
Driver problem? Updated to latest (it improved my 3DMark score
but no fix. Even checked al display settings.
Heat problem? removed heatsink, cleaned, reaplied thermal past, no affect.
Incorrect BIOS settings? double checked.
Thoughts? Suggestions?
