1 - 11 of 11 Posts
A co-worker asked me to repair his PC today...it's a Pentium 4 with an ATI Radeon 9800 Pro video card...he said it's been repeatedly crashing to a black screen. I turned it on and ran it, and the card worked fine at first, except the fan doesn't spin, so the card gradually heats up until it crashes. I already tried running it with a different molex connector, and the same thing happened. Is the video card done for, or is there a fix for this problem?
Thanks guys!
What fairly inexpensive fan do you recommend for a Radeon 9800 Pro?
STG3 VET
Discussion Starter · #6 ·
Awesome - thanks (and rep+)
Should run fine even with the 4 buck heatsink there. They weren't exactly the most heat-generating cards as far as I remember (unless I'm confusing it with the 9600 Pro)
Iconoclast
You can just replace the fan, and keep the heatsink as is, or you can replace the whole HSF.
Originally Posted by Juggalo23451
VIO Twinkling VGA Cooler - VGA Cooler for nVIDIA, ATI, SIS Chipsets
http://store.cwc-group.com/viovgacovgac.html
3.75
That will not cool a 9800Pro adequately.
The 9800Pro ran extremely hot with it's stock cooler, and the stock cooler has at least three times the surface area of that 4 buck heatsink.
You must be.
The 9800Pro is a ~60 watt card. That's on par with modern, lower mid-range GPUs. It was the flagship card of it's day, and really should have had a 2-slot cooler. I used to have one.
The 9600 pro used ~20w.
1 - 11 of 11 Posts
