1 - 3 of 3 Posts
I have an EVGA GTX 670 FTW and an ASRock Z68 Extreme3 Gen3 (and the case is an NZXT Phantom), and I cannot get the card to fit properly in my case! I just added a waterblock (Heatkiller GPU-X3 LT) and not it won't go down all the way. I don't there are any clearance issues, so can anyone give me some suggestions on what to do? Thanks
Originally Posted by Legonut View Post
Does the motherboard have little tabs for locking the GPU into the board? You need to pull those to the right.
Yeah I pulled them. The card goes in, but the side towards the IO sticks out about a mm. Enough so that it doesn't make that "click" noise you'd normally hear.
1 - 3 of 3 Posts
