1 - 2 of 2 Posts
· Premium Member
Is there a way to have all files and folders within 1 folder to all view the same way? Its a pain in the butt to go into each subfolder and go to view, and then click list. This is for all my music files. A lotta albums and individual tracks. Any tips are appreciated, thanks!
Edit - Now that I'm thinking about it, how do you make windows, such as IE, all open in the same size? That can be irritating when all these windows are opening in different sizes and areas of the screen. Thanks!
Problem 1) Folder options > Apply to all button.
Problem 2) Open a window, maximize it. Go to File > New if it isn't maxed, maximize it then close the first window. Close the second window then open IE again and it should be maximized.
1 - 2 of 2 Posts
