1 - 20 of 20 Posts
is it me or this psu isnt any good everything just moves up and down yes everything and it makes wierd sounds 2..when i go to the bios nothing is steady just jumps around that cant be normal even my thermaltake 480 didnt do that, is this normal..p.s no i havent had a drink yet :shades2: ..
I've trapped my arm and blood is rushing out. Is this bad?
Take that piece of junk out of your machine quickly mate.
this is what i wrote down as i watched it..
vcore..1.358...1.368...1.348..1.397
3.3v....3.29....3.344....3.360
+5.0v.....5.193...5.219....5.114
+12.0v....12.73....12.8....13.061
-12.0v....11.9....12.153....12.071
battery....5.066....4.97....5.044
and these move with out stoping...
Your 12v rail is throwing too much voltage out and it's unstable. seriously take it out of you system before it damages anything.
Reactions: SINISTER
well i decided to just shut down the intel system for now my amd system is just to much to disassemble lol ,but im going to compusa and they just got the ocz 420 wt.i looked online, im going to get that one ..this week..now on my system with the thermaltake 480 butterfly...
vcore..1.75...1.76
vcc voltage (+2.5) ..2.61...2.63
i/o voltage (+3.3) ...3.32...3.33
+5.0v...5.03
+12v....11.56...11.62...11.68
12.v ...11.87
-5v...-5.10
3.3 dual voltage...3.56...3.54
battery 5.0...5.49
much better so that vigar is a piece of crap.
Discussion Starter · #11 ·
lol i know bro , i should have known better but i never seen it in the bios like that before just movin all over the place lol ..well i just wanted to see ..i saw now its gone ..
Discussion Starter · #12 ·
Originally Posted by Ryan
Wow, that's the same psu I got. I haven't got my whole system up yet but got it cuz every1 seemed to like it?!? And it's so pretty... Maybe yours is just bad
well i tell yea . even if i do have a bad one dont that kinda tell you about the quality of there products..and there quality control..i wouldnt suggest anyone of buying this psu..but if you want to keep yours keep your fingers crossed...
Discussion Starter · #15 ·
ok heres what i wrote down as i see it it changes ever sec
cpu temp 36,37,55 c
system 22,24,25 c
cpu fan 2678,2766,2721
vcore 1.329 1.339,1.344 1.358
3.3v 3.312 , 3.328 , 3.344 3.280 , 3.296
+5.0v 5.140 , 5.160 , 5.114 , 5.167 , 5.193 , 5.219
+12v 12.473 , 12.669 , 12.538 , 12.604, 12.212 , 12.408 12.342
-12v 12.153 , 12.235 12.317
battery 2.960 , 2.992 , 3.008 , 2.976
+5v sb 4.987 , 5.013 , 4.993
i downloaded speed fan it also say 12v is high
dont take any windows based prog as 100% correct. on my xp board speedfan showed my +12v rail at 12.98-13V+. core center always showed around 11.70v which was almost on spot w/ the bios.
1 - 20 of 20 Posts
