1 - 11 of 11 Posts
My RAM is really low and I can't buy any more ATM, my mate told me that he uses a program that uses up HDD space as RAM.<br>
Anyone know the software/more info?
I think that's impossible, may slow the HDD down and....o.o
Tweak XP has a feature like that, but I don't know what it exactly does or how it works. Download that trial of Tweak XP and it should be under the hardware tab>virtual ram. I wish I had the progy installed.
Can you post your system specs in the "Usercp" and maybe we can help you out.
Just post them, who cares, some people ran like pentium I, II. Duron and puts their specs. It might help you.
<div>Originally Posted by <strong>FearSC549</strong></div>
<div style="font-style:italic;">I think that's impossible, may slow the HDD down and....o.o</div>
</td>
</tr></table></div>
No it isnt - Its called Virtual memory and you will find it in<br><br>
Control Panel > System > Advanced > startup + Performance . Virtual Memory <img alt="" class="inlineimg" src="/images/smilies/gunner2.gif" style="border:0px solid;" title="Gunner2">
So, can i try it??? And will my pc be faster?
<div style="font-style:italic;">So, can i try it??? And will my pc be faster?</div>
</td>
</tr></table></div>
It is very hard to explain how you pc will differ performance wise, It will not make the pc faster but you will not run out of ram when your are using virtual ram.<br><br>
I will look for a description of it <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"><br><br>
EDIT: Found one - <a href="http://computer.howstuffworks.com/virtual-memory.htm" target="_blank">http://computer.howstuffworks.com/virtual-memory.htm</a><br><br><div style="margin:20px;margin-top:5px;">
<table border="0" cellpadding="6" cellspacing="0" width="99%"><tr><td class="alt2" style="border:1px inset;">The amount of hard drive space you allocate for virtual memory is important. If you allocate too little, you will get "Out of Memory" errors. If you find that you need to keep increasing the size of the virtual memory, you probably are also finding that your system is sluggish and accesses the hard drive constantly. In that case, you should consider buying more RAM to keep the ratio between RAM and virtual memory about 2:1. Some applications enjoy having lots of virtual memory space but do not access it very much. In that case, large paging files work well.</td>
</tr></table></div>
1 - 11 of 11 Posts
