Virus?
905 Views 10 Replies 6 Participants Last post by  TheGrayNobleman
I think I have a virus of some sort on my sytem. Ony of my CPU's is pretty much always at 80-90% load and it's really making things crawl here. I use Panda Antivirus and Windows 7 Professional, what can I do to check and try to remove it?
1 - 11 of 11 Posts
Err, have you tried looking in Task Manager to see what process is hogging the CPU?
Firstly make sure that there is nothing running that's not supposed to be like a defrag tool or something? If not and a 'full' virus scan isn't showing anything up, Then download and run this malwarebytes. Version 1.41.
Yes, there's no process taking more than 4% CPU (and that is Google Chrome), which is what got me worried.
Nothing extra running. I'll try malwarebytes. Thanks!
Then how do you know that your CPU is up at 80-90% load?
I'd recommend Spybot S&D as a spyware scanner
Performance tab of the task manager says it was at 80% load, but there was no service using more than 4% CPU power.
If Malware Byte's doesn't find anything I'll try Spybot.
In Task Manager -> Processes tab there is a box at the bottom which says "Show processes from all users". Check it and you will see what takes up the CPU juice
Give this a shot - Windows doesn't always show it's own processes. It's easiest to sort the list into order by CPU usage by clicking the title of the column - that way, whatever is using the CPU resources up will be at one end of the list
Well this is kind of ironic as when I uninstalled Panda to install MalwareBytes the problems went away. Be damned Beta versions of software!
Malware Bytes did find two threats and removed them though, thanks for the indication!
Download a program called Process Explorer to see what's actually running.
I would also recommend switching to Avira for an anti-virus because its overall one of the best anti-virus programs out there (see my sig for more info).
Lastly, download CCleaner and see what boots (and disable it <- only if you know 100% what it is).
1 - 11 of 11 Posts
