1 - 13 of 13 Posts
Is there any way I can upgrade from 32bit to 64bit?
I know you can't upgrade it directly.
I was wondering if I could clean install from Vista to Win 7.
Thanks!
You can clean install from any OS to windows 7, simply format the partition and install Win7, or install on a free partition.
Look at the chart below to determine if you can upgrade.
Clean install is the only way. And a clean install is not an upgrade, you lose everything. There is no way to upgrade from 32 bit to 64 bit without losing everything.
1: Get an external HDD
2: Back up the most important files
3: Clean install
4: Put the files back to whatever the HDD letter is that you use
5:
Discussion Starter #5
i know how to clean install but i heard a rumor that windows disabled clean install on upgrade cds
can anyone verify this?
That's pretty much wrong.
If your upgrading from say Win 2k or XP Pro to Win 7 home edition, your forced to do clean installs. Upgrading from Vista Business to 7 home, you got option to either do clean install or upgrade in place. You'll be forced to do a clean install nevertheless from a 32-bit os to 64-bit os.
I know this since both my copies of Vista and 7 are retail upgrade editions.
The Computer Guy
upgrade dvd are locked,can't use them to do a clean install
Discussion Starter #8
thought so... thus i can't really go to win 7 64bit unless i have vista 64bit right?
Not by upgrading, but you can clean install to your heart's content.
Backing up your files and clean installing the OS is, in my opinion, a good thing to do every now and then anyway.
No there not, there's been many a hacks to get a clean instal from an upgrade media. It's not against TOS either as it doesn't break any real rules. Since your allowed to upgrade, the only option being a clean install, your allowed a clean install.
There is no way of directly upgrading between the two operating systems. In my situation I'd either backup all my wanted data onto an external HDD or onto an extra backup partition. And then I would format the windows drive/partition with a bootable format program then I would re-install windows and transfer my wanted data back to where I need it.
1 - 13 of 13 Posts
