Vista 64 VS XP 64
897 Views 4 Replies 4 Participants Last post by  CuriouslyHigh
Whats up my homies
I am trying to decide the difference between these two operating systems..
so i thought id ask you guys
one big thing im trying to do that all i care about is run the max ram i have purchased, thats 8gigs, but i dont know if i can do that with xp 64, can I???
in the long run, i will be turning off every extra function on the operating system so i can get maximum performance....
so do i need home or business???
thanks guys, as always
1 - 5 of 5 Posts
Vista. Drivers are much better.
Vista x64, drivers are better. Vista allows a better gestion of memory
Vista. If for nothing else, for DX10, and better support.
You have a 9500gt. That's basically a 8600GTS. That's basically a 7600GT. That's basically a 6800Ultra. So it's decent enough to definitely do some DX10 gaming, particularly in Assassin's Creed, which works better in DX10 mode.
1 - 5 of 5 Posts
