Updated : FED- 17- 2008
Sorry for the huge pictures.
Ok, I found a small software that called Vista Anti-Lag that fixed my problem, you can DOWNLOAD it from here.
I have posted 2 pictures to show you before & after. REP me if that helped you
Vista Anti-Lag Inactive
Vista Anti-Lag Active
| I can't play any online game because of this problem. I used to have Vista Anti-Lag, but i's not working anymore. This problem happen with wireless users. see the proof below. If you have Vista, and you are using a wireless, please let me know if you are getting the samething. 1- start menu type "CMD" then hit enter 2- type "ping -t www.yahoo.com" then enter P.S you can use any server or IP address. I found a Fix ================================================== === Temporary Solution ================================================== === 1- Start menu type" Services " Hit enter 2- Look for WLAN Auto Config 3- Right click, and properties 4- Change the startup type to "Disable" 5- Restart you system The Bad Thing:- you won't be able to see other networks ================================================== ====
