Vista not booting since installing new motherboard
763 Views 17 Replies 8 Participants Last post by  Sgtbash
Hi all
I bought a new motherboard yesterday (Abit x78) ans have been dual booting in the past, with vista home x64 and premium x86. Anyway, when i installed my new motherboard i put my premium disc in and decided to format all my old drives and start afresh. So it was installing like it should and i could boot up into it but when i shut it down i cannot boot back up into it, it says that its booting it into vista via the dual boot screen, and it just stops there and nothing happens. What should i do?
1 - 18 of 18 Posts
try reinstalling. sucks but it just doesn't seem right that it would do that right after a install without something being corrupted
Ive tried to install premuim and ultimate multiple times, to no avail
(same problem)
sounds like ur bootloader is pointing in the wrong direction. try using a linux live cd and editing the boot.ini files.
How do i go about meesing with the boot.ini files? and can anyone point me directly to a linux iso please?
go here and get the live cd
edit: here's the download page for convenience
Thanks a bunch, downloading now.
So after im running it and stuff, how do i go about messing with the bott.ini and where can i find it?
Correct me if I'm wrong, but since he's reinstalled multiple times, wouldn't that have started him with a new boot.ini? Therefore ruling out that being the solution.
Also, do you currently have a dual boot set up? Or just a single OS?
Ive formatted all HDD's (2) and im just trying to install one at the moment.
^^^^IM guessing its all just a BIOS boot reorder...apparently it installs the bootloader on the secondary drive....but the PC boots the original bootloader on the old...switch the boot order presto whammO > no need for the boot ini edit...what a headache >either way install disc should "repair" the bootloader IF=corrupt/damaged
to edit the windows vista boot 'd use bcdedit.exe dont know if it'll run under linux though.
get into the recovery console and type in fdisk/mbr it will fix your boot record of whatever drive is your primary.
So format both, make sure you install it on the HDD that's in the first SATA port as to not confuse anything, and you should be fine.
The chance is that your ram is preventing a successfull install, remove all but one ram module, reformat and try to install again. If you can get into Windows successfully you can always add the other modules afterwards.
Tryd everytnig suggested guys, still to know avail. (im typing on my comp withn linux btw on a live cd )
gentle bump... I need help guys, i cant even use my comp properly, please help
/Thread, case solved my mobo was to blame, told me only to enable a n option if i use 64-bit and even though i use 32 bit it worked a charm
1 - 18 of 18 Posts
