1 - 20 of 24 Posts
Hello, I was wondering what is the difference between the Windows Vista Upgrade and Windows Vista Full? I mean, does the Upgrade requires Windows XP just for authencity that you had XP or it upgrades your Windows XP to Vista?
Retired
Upgrades require that a previous version of windows be installed on the computer. Full versions do not.
Yeah but technically why does it require it? Just has a proof you had Windows XP or it's acutally upgrading Windows XP to Vista?
9 Cans of Ravioli
...Its so if you want to upgrade, you don't have to buy a new version.
If you don't have an OS on your computer and you want to install it, you can't.
In order to reinstall with the upgrade, you would have to install the windiws XP, then install vista. If you get the full version, bye XP!
Discussion Starter #6
Ok then full is better right? To avoid corruptions? Or it's as good as performing a full install?
Retired
Its just marketing. Why should a consumer pay full price for an OS when they have been loyal to said company. Its one of the decent things M$ does, allowing one to buy an upgrade. They usually cost much less.
9 Cans of Ravioli
It sees you have XP, deletes it, installs Vista.
Non-upgrade version checks to make sure you rig is up to spec, then installs.
Not much to not get.
Discussion Starter #9
I'll rather install a full then, so I can reformat my drive to make sure I have no conflicts with some files from my previous OS even though it was removed. Would an upgrade allow reformat though? to completly remove XP?
I'm not sure how Vista's upgrade will work, but with XP you can still do a full install with an Upgrade disk. At setup, it prompts you to insert a Microsoft Windows Operating System disk, and then setup will continue. You CAN do a full setup with an Upgrade cd.
It can be even easier than that. All you need is the cd. If you dont have an operating system like xp installed but you have the disk, during instalation of the new operating system it will ask for the old disk to make sure you have it.
Discussion Starter #13
awesome. okay that's what I hoped and thought, thx a lot men. My only worry now is that I'm running a wireless at home and I have a PCI Wireless Adaptater and I'm not sure if there will be any drivers supporting it on Vista. And that means if there aren't, no internet on this comp.
9 Cans of Ravioli
*edit*
Beaten to it.
Haha, 3 of the same answer all within 1 minute
Smart minds think alike
Discussion Starter #17
You guys gonna buy it as soon it hits the shelves?
Retired
No, im going to use RC1 until it expires. By that time hopefully most of the obvious bugs will be worked out and then I will consider purchasing Vista. Im happy with XP.
Discussion Starter #19
RC1 running good as primary OS?
Retired
Im running it as a secondary OS, only use it when im doing stuff like surfing the web, and stuff. I really like the new UI. WinXP is still my primary OS.
1 - 20 of 24 Posts
