1 - 3 of 3 Posts
My Windows Vista 64-Bit won't sleep anymore. When i first installed it, I would always put it into sleep. That worked for about a month. Now it doesn't work at all and just hangs. I don't know what the problem is. Any advice?
Possibly a device or software prevents it from sleeping, for example if a software or device requires computer ressources and cannot be interrupted, the computer might not go to sleep. USB devices could well be the cause, try again by unplugging all your USB devices except for like the mouse or something.
Did you try a warm glass of milk? Kidding aside. I have the same issue with my Vista. I have to reboot the rig back up, it wont go into sleep mode. It acts like it's sleeping, but it wont "wake up" from this state. I literally have to hit the power button and reboot.
1 - 3 of 3 Posts
