Vista X64 only seeing 3191MB of ram?
438 Views 8 Replies 7 Participants Last post by  whitt_flunky
Well on one of my computers (my bedroom one if you care to see the specs) has Vista x64 on it, with a motherboard capable of having 4GB of ram, and well it only sees 3191MB of my ram, not 4096, could that be because the GPU is integrated?
1 - 9 of 9 Posts
Yes. Go into the Bios and see if you can lower it down to 128m.
also in the bios,make sure that your hardware memory hole is enabled
In the bios, enable Memory Remapping - this is more than likely disabled
Originally Posted by Maddog7771 View Post
do you have sp1??? OR no
Indeed I do.
I will go into the bios and try to change that stuff. Will report back.
ok just checking because some times vista non sp1 will do that. NO but resetting the seeings and some other things should fix that but it is still odd because even if it maps it it should still show up
Does the integrated GPU use shared system memory?
An add on PCI-E video card will disable shared video memory in the BIOS.
1 - 9 of 9 Posts
