Hi guys!
I was just curious to know if anyone knew how to change the playing track on VLC using the mouse hotkey without causing the program window to open/show.
I'm using a Roccat Kone + on Windows 7 64 bit and using the mouse's SHIFT key + Tilt Mouse Wheel left/right it is possible the change the track but the VLC window pops up - the whole point of using the shortcut is to change track without interrupting my working / browsing etc.
I haven't had much luck with Google and VLC doesn't recognise the Mouse-key-combo in it's Hotkey options (although it clearly works).
Any ideas? I change tracks a lot while working!
Thanks in advance
Thanks in advance
