volt moding gtx 960m
3100 Views 4 Replies 3 Participants Last post by  kalo4747
hi everyone any got mod for gtx 960m mobile gpu can help me
1 - 5 of 5 Posts
No, Its a mobile GPU with gddr3 thats not compatible with other maxwell vbios.
If anything you should be seeing how far you can undervolt this. You're working with with a 150w Battery as a power supply. You need to lwoer your expectations and get used to gaming at medium settings @ 720p unless your willing to upgrade.
A 960m is basically a 750 with no gddr5 iirc.
Im pretty sure I posted this in your other thread you made.
thanks for info gpu is gddr5 not3 and i can still play 1080p gaming with 30 fps overclocked it to runs 1440 mhz core clock mem 3370 mhz just cant undervolt or add volt
How do you reach that frequency?? I have the same card on a Dell Inspiron 7559 and I can't go past +135mhz.
For voltage mod: if you use MSI Afterburner to oc, you can activate Unofficial Overclocking mode that consent to modify voltage.
you have to mod vbios to pass +135 limit
1 - 5 of 5 Posts
