1 - 3 of 3 Posts
just wondering if the powercolor 6870's r able to b voltage overclocked??? Ive tried to enable it in afterburner but with no luck? I can overclock my cards to almost max and r stable but seem to do worse in benchmarking, im thinking they need more juice to get out bigger numbers. Ne ideas?
My mate has a powercolor 5870 and he can't change the voltage, I am not 100% sure but I think its the same with your card. Also I think if your getting worse results in benchmarks that your memory is Overclocked too far.
I think it would just be unstable or you would see glitch's(Artifacts)in the benchmark if you needed more voltage.
Hope this helped.
Thanks, Sir Overkill.
1 - 3 of 3 Posts
