1 - 7 of 7 Posts
What voltage should I be running at overclocks of 850 core / 2110 mem?
Right now I have it at max (1.087v) for stability, but what voltage should I have it at?
Every card is different
I run 850/1700/1800 OCCT stable at 1.050v, vid of 1v. Not sure you'll get much more out that card, mine only goes to 860 at 1.087v.
To maxmize your performance I'd advise you to drop the memory overclock and focus on core until stability becomes an issue. Memory ocs on the 460 will potentially hold your core oc back whilst not increasing performance nearly as much as the core oc.
Discussion Starter #6
Even at stock clocks for memory, I can't get more than 850 stable.
I got mine with no errors at 875 stable in OCCT. Had to bump my voltage to 1.087v.
850 with 1.05v.
825 with stock voltage, which for my card is 1.012v
1 - 7 of 7 Posts
