1 - 2 of 2 Posts
I set my voltage to 1.200x133% so the Vcore should be 1.596. It even shows it in the BIOS as 1.59. But when I use CPU-zit shows 1.568, Speedfan shows 1.57. So what is the real voltage I'm getting?
Bios is correct. Software is often reading off by a little bit. The differences you are seeing are minimal.
1 - 2 of 2 Posts
