Hi guys just a quick question. I'm running 2x 5870 in crossfire with a GTS 250 for Physx. Since i installed the physx card smartdoctor wont work.
So if i un install the 250 card and then use smartdoctor to adjust my voltage, will the adjusted voltage stick if i uninstall smartdoctor again. So in summary is the voltage adjustment only going to work with smartdoctor running or will it be independant after the adjustment to voltage.
Cheers
Cheers
