1 - 1 of 1 Posts
Hi.
I modded a 6850 from gigabyte using the fb to gnd mod.
Now i have a switch to turn on and off the mod, the problem is even when the mod is off the pc boots up and everything's ok but when i try to run a benchmark or anything the vcore drops to 0(with a multimeter on the back) fans go 100% and suddenly no more vga signal.
Any idea why this behavior? It s not a short circuit because i used hotglue and electrical tape to fix everything.
To me seems strange because it happens even when the mod is off, and it seems to be random. If i did a bad solder touching the nearby resistors it should behave always the same and not randomly working and going to 0
1 - 1 of 1 Posts
