1 - 3 of 3 Posts
Still kinda lost
So I just started going all VPN instead of using it when I need it and noticed that the flag next to my name is showing (What ever I am tunneling through) so is it possible to force the flag to be connected to what ever we choose in the location tab.
Administrator
Here are the current options for your location:
Click on your avatar, near the upper right-hand corner of the site. Select account settings from the drop-down menu.
On the account settings page, scroll down to location.
As you start typing your city, it will offer you choices appear in the drop-down menu. Click to select the one that displays your location.
If you prefer to only display your state, simply type your state, and then click on it in the drop-down menu.
Within discussion threads, you will see your country flag displayed under your username.
User Location Privacy Settings
Click on your avatar and select Account Settings from the drop-down menu.
Your Account Settings page will open with more options. From the left-side navigation bar, select Privacy.
On your Privacy page, you will see options regarding your location.
Use the drop-down menu to select who can see your location information.
Save your privacy settings.
Jeff M
Still kinda lost
Thanks a lot, it worked.
1 - 3 of 3 Posts
