1 - 20 of 47 Posts
i got a His excalibur X1300 IceQ turbo card / win Xp MCE pro<br><br>
cant play any games properly<br>
like if i open a game i get like 5mins playing and then it recovers<br>
after 1st recove rlike 2mins then again and 3rd time whole comp jamms and i have to reboot<br>
is the problem in win or what ?<br>
im really pissed.<br>
can someone help me :S?
I used to get that on my old 9500... it was overheating. Check temps, then try new drivers if you're not on the latest ones.
Hey -.-<br>
im usin Iceq turbo no overclock i dont think temps are bad.<br>
i checked too and they r ok and usin latest drivers
You could just go into the CCP and switch it off.
Discussion Starter #5
I switched it off but if i do that i play like 5mins and then my cp jamms... :S<br>
Discussion Starter #7
me neither :S <br />
this really sucks. :S<br />
maybe its the win problem ? <br />
maybe the card doesnt like that win -.-`??<br />
it pretty early build of mce too
Administrator
No VPU recove happens when theres an issue with the following. <br />
<br />
1. Problematic drivers <br />
2. PSU instability <br />
3. Overheating. <br />
<br />
Check its temp in a program called ATI TOOL here:<a href="http://www.techpowerup.com/atitool/" target="_blank">http://www.techpowerup.com/atitool/</a> and tell us what temp you get. <br />
<br />
As for installing new drivers for it do the below : <br />
<br />
Installing Graphic card driver efficiently!!! When you Update your graphics cards drivers theres ways that you should go about it. Follow these simple steps below. <br />
<br />
1.Download and install ''Driver Cleaner'' Here:<br />
<a href="http://www.drivercleaner.net/professional.html" target="_blank">http://www.drivercleaner.net/professional.html</a><br />
2.Uninstall your Current Display drivers such as your ''ATI'' or ''Nvidia'' drivers. <br />
3.Now run ''Driver cleaner'' and depending on the Drivers you have you will have to select either ''ATI'' or ''Nvidia'' from the drop down menu. Only select the main title of the driver in the drop down such as just ''ATI'' or ''Nvidia''<br />
4.Once you have selected Your driver click on the ''Start'' button and this will now start the driver cleaning process. ( Do this twice to be sure ) <br />
5.Now reboot your system and Download the latest Nvidia or ATI and go ahead and install them. <br />
<br />
Doing this avoids driver corruption and conflicts so you can now enjoy smooth gameplay. <br />
<br />
As for a Power Issue can you please tell me the specifications of your PSU such as th Watts and Amperage on the 12v rails...Such information can be found on the sticker on the side of your PSU.
Discussion Starter #9
1st. somehow atitool doesnt show my temp :S<br />
2nd. atitool jamms after 15sek of use<br />
3rd. im doing the drive rstuff now<br />
<br />
but i think temp should be okay since its IceQ and fan works well
Administrator
<tr>
<div>
Originally Posted by <strong>CCooki33</strong>
</div>
<div style="font-style:italic">1st. somehow atitool doesnt show my temp :S<br />
<br />
but i think temp should be okay since its IceQ and fan works well</div>
</td>
</tr>
</table>
</div>If you cant get anything to work for ATI tools then please get ATI TRAY TOOLS here :<a href="http://www.guru3d.com/article/atitraytools/189/" target="_blank">http://www.guru3d.com/article/atitraytools/189/</a>
<tr>
<div>
Originally Posted by <strong>ENTERPRISE1701</strong>
</div>
<div style="font-style:italic">If you cant get anything to work for ATI tools then please get ATI TRAY TOOLS here :<a href="http://www.guru3d.com/article/atitraytools/189/" target="_blank">http://www.guru3d.com/article/atitraytools/189/</a></div>
</td>
</tr>
</table>
</div>X1300 doesn't have a temp monitor <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Discussion Starter #12
but that vpu errors are ONLY ingame<br />
<br />
if not playing then everything is ok<br />
<br />
doesnt have a temp monitor o_O ?<br />
<br />
but still its IceQ it cant be too hot =) <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Administrator
<tr>
<div>
</div>
<div style="font-style:italic">but that vpu errors are ONLY ingame<br />
<br />
<br />
<br />
but still its IceQ it cant be too hot =) <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>Well indeed it doesnt have a temp monitor. Even if it is IceQ it may run hot due to a faulty or not very well installed cooler.
<tr>
<div>
</div>
<br />
<br />
<br />
</td>
</tr>
</table>
</div>Apperantly you don't know much about electronics. When the GPU starts getting load (Windows has a FPS limiter, which does that the GPU doesn't overheat, and only has to update with ONE texture (VERY simple task), therefore it runs cooler than in games.<br />
And no, it doesn't have a temp. diode/thermostat etc.<br />
<br />
And yes, it can easily be too hot.
Discussion Starter #15
=( <br />
i have a natural cooler too <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> window is like half meters from window what is always open and out there is like pretty cold <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <br />
like 10C u have to wear a jacket to go outside 0.o
Discussion Starter #16
Ohlol how can i have missed that.<br />
i had an old nvidia driver installed too<br />
i have my comp full of crap at the minute planning a format soon <br />
could that have been the problem !?!?<br />
anyway going to test now if it still messes with me...
Driver conflicts could easily have been the problem.<br />
<br />
If it still messes up, I join the crowd that suspects your temps. You might have applied too much thermal past, or not screwed on the cooler tightly enough. The fact it does crash after a few minutes really indicated temperature problems.<br />
<br />
Finally, the other posibility is a PSU that's just not up to the task, but I would expect reboots in that case.
Administrator
<tr>
<div>
</div>
<div style="font-style:italic">Ohlol how can i have missed that.<br />
anyway going to test now if it still messes with me...[</div>
</td>
</tr>
</table>
</div>Yrs driver conflicts can cause this problem make sure you remove all drivers using Drivercleaner.
Discussion Starter #19
i have just done that<br>
have played half hours no problems testing tomorrow too and if it works<br>
i'll really thank you for the help <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Discussion Starter #20
my card is like 1 week old -.-
1 - 20 of 47 Posts
