Source
Getting the best doesn’t have to mean paying a lot, and that’s especially true with the XFX’s Intel chipset-based motherboardâ€"the XG3li motherboard. Offering exceptional performance for the true budget conscious user, this motherboard is built with affordability, performance and reliability in mind. Built to support Intel LGA 775 processors, the XG3li can support up to 4GB of dual channel DDR2 800 MHz SDRAM, delivering up to 12.8 GB/s (DDR2 800 dual 6.4GB/s) of bandwidth and 4GB memory addressability to increase system responsiveness and support for 64-bit computing. The XFX XG3li motherboard supports up to a 1333 MHz front side bus. Performance is further plussed with Intel-exclusive features including Intel® Fast Memory Access, which improve system performance by optimizing the use of available memory bandwidth and reduces the latency of the memory access. Additionally, Intel® Flex Memory Technology enables easier upgrades by allowing different memory sizes to be populated and remain in dual-channel mode. And, the Intel® Graphics Media Accelerator 3100 helps pop frame rates and enhance the user experience, a feature especially noticeable when using Windows Vista. Being Vista certified also helps improve system stability and compatibility. Premium High Definition Audio (HDA) brings consumer electronics quality sound to a user’s PC by delivering high quality sound from multiple channels. Using HDA, systems can deliver 192 kHz/32-bit quality for up to eight channels, supporting new audio formats. The XFX XG3li motherboard also features PCI Express bus architecture with a full bandwidth x16 expansion slot. Users can enjoy blazing performance by taking advantage of the latest SATA 3 Gb/s hard disk drives that offer double bus bandwidth. Not only are these high-performance drives easy to install, they consume less power than EIDE hard drives. Additional XFX XG3li motherboard features include a rear panel e-I SATA port, rear panel clear CMOS button and on selected models, a Debug LED. |
Source
