PC SPECS:
Motherboard: AB350 Fatality k4 gaming
CPU: Ryzen 5 1600
GPU: EVGA GTX 1060
PSU: Thermaltake TP 775
The thing is i ran the firemark3d TIMESPY recommend by the software and i let the HWINFO64 runs in background, and the vrm seems to stuck on 29? is that normal or is it bug?
PS: I never overclock at all i just followed AMD guides, only changes CPU VOLT from 1.2 to 1.3 to achieve 3.8 speeds
And with the ram 2x4 patriot 3200 16-16-18/36 with XMP profile 2.0 also ram came default 1.35 i never touched that
I did this benchmark with my pc on CPU STOCK, and ram stock 0 overclock:
I'll attach 4 pictures of the Hardware Info 64, so you can tell if something is weird or not? thanks in advance:
Thanks for your time.
CPU: Ryzen 5 1600
GPU: EVGA GTX 1060
