41 - 60 of 80 Posts
I'm afraid I have bad news for you, but you cannot get rid of performance issues while using ADL to access I2C or perform some other time-critical hardware monitoring related tasks. Sadly many parts of ADL API are deadly inffective and can be hardly targeted for usage in performance critical realtime monitoring tools. That is why MSI AB, Trixx, GPU-Z and most of other tools use their own low-level drivers performing direct access to I2C microcontroller registers and doing that much faster than ADL can do. And yes, it is absolutely necessary to use synchronization mutexes used by all those tools to avoid low-level/ADL I2C access collisions.
And BTW, power draw displayed by GPU-Z And AB cannot be read from I2C device or via other ADL API. It is being read from SMC and own low-level driver and direct access to hardware is also required to perform that task.
hyy,
i want to undervolt the 470/480 in the bios (set an offset)
I have analyse the ROms with Hex Editor und AtomBioseditor and so an... i tryied some flashes.. but der is not working. ( add VDDC and VDDCI offset "inside" the rom with a HexEditor - but i dont exactly where in the ROM)
have someone the Solution? / tried it?
lg blue
Hello there.
I tried to get it work with my r9 290 and win 10 64 without success.
I got an error even after installing all the Visual C++ and the .dll it ask.
VRMtool.exe - Application Error The application was unable to start correctly (0xc000007b).Click OK to close the application.
Some ideas for get it working?
Originally Posted by Wimpzilla View Post
Hello there.
So this problem was really bothering me, because i wanted really try this out.
So i used dependency walker to find out witch api ware missing.
Seems the tool need both, or at least, the Microsoft Visual C++ 2015 Redistributable Update 3 x86 and maybe x64.
I was missing the x86, lol, now it is working on my R9 290 on win10 x64, lets try to not fry the card.
Edit: As far i know everything work on the 290, tested each settings. This tool is truly awesome, who need MSI AB anymore.
Doesn't do jack on the XFX RX 480 8GB GTR-S Black Edition
Can't read anything
It works though on the ASUS RX 570 4GB Strix Edition
My favorite app for undervolting. 0.816Vcore @1180Mhz (for mining). Awesome!
That's awesome since the TRIXX was making the 570 chip go haywire
Discussion Starter · #47 ·
Can't read anything
Sounds like the GTR-S has a different voltage controller that I don't support (yet) with VRMtool.
OMG you are back!
Thx you so much sir for this tool, this is for me the best Hawaii/Polaris power management tool.
I use it along the Relive driver clock control, never had anymore 3rd party driver issues when overclocking.
Please if you can, keep the tool update, i really wish you along the community that helped, will bring the same seriousness tool for vega gpu.
A fish with teeth!
Is there a way to determine which controller a given card has in Windows? Maybe with an AIDA64 dump? I'd like to figure out which cards have IR3567B vs. NCP81022 vs. uP9505 so I can proceed with trying to tweak VDDCI and LLC, etc.
If not, what's the process for doing this in Linux? I'm a Linux n00b but I could muddle through. Is there a built-in tool to safely probe the controllers over I2C or would I have to grab it from some repository or compile it?
Discussion Starter · #51 ·
You can try dumping the i2c bus using aida64 or afterburner. In the dump you can then see if you find the identifying registers of the different VRM controllers.
A fish with teeth!
I see a bunch of 4-byte hex strings but I have no clue what I am looking at. Can you elaborate on how to find the identifying registers? This is a dump of one particular MSI card.
------[ ATI GPU #2 @ mem FE8C0000 ]------
Video Adapter = AMD Radeon RX 580 (Polaris 10)
GPU Code Name = Polaris 10 XT
PCI Device    = 1002-67DF / 1462-3418
GPU Clock    = 1326 MHz
Memory Clock = 8000 MHz
GPU    Base Clock = 100000 kHz
Memory Base Clock = 27000 kHz
ati-$002F4 = 00007300
ati-$02004 = 00433210
ati-$02408 = 000F007F
ati-$025B8 = 00000001
ati-$02760 = 000060A2
ati-$029C4 = 00004442
ati-$029EC = 00000000
ati-$029F8 = 00000000
ati-$029FC = 00000000
ati-$02A00 = 506076F2
ati-$02A04 = 20140A0E
ati-$02BA0 = 00000000
ati-$02BA4 = 00000000
ati-$02BB0 = 00000910
ati-$02BB4 = 00000366
ati-$02BB8 = 00000000
ati-$02BBC = 00090004
ati-$02BC0 = 00000000
ati-$02BC4 = 00000000
ati-$02BCC = 00000000
ati-$02BD0 = 00000000
ati-$03688 = 6400FF68
ati-$0368C = 00000000
ati-$03690 = 000FE830
ati-$03694 = 007F9210
ati-$03698 = 00000050
ati-$0369C = 0153004F
ati-$036A0 = 00000000
ati-$036A4 = 00000002
ati-$036A8 = 00000014
ati-$036AC = 00400000
ati-$036B0 = 00000000
ati-$036B4 = 002A0000
ati-$05428 = 00002000
ati-$089BC = FE000001  [SE0 SH0]
ati-$089C0 = 00000000  [SE0 SH0]
ati-$089BC = 00000000  [SE0 SH1]
ati-$089C0 = 00000000  [SE0 SH1]
ati-$089BC = FE000001  [SE1 SH0]
ati-$089C0 = 00000000  [SE1 SH0]
ati-$089BC = 00000000  [SE1 SH1]
ati-$089C0 = 00000000  [SE1 SH1]
ati-$089BC = FE000001  [SE2 SH0]
ati-$089C0 = 00000000  [SE2 SH0]
ati-$089BC = 00000000  [SE2 SH1]
ati-$089C0 = 00000000  [SE2 SH1]
ati-$089BC = FE000001  [SE3 SH0]
ati-$089C0 = 00000000  [SE3 SH0]
ati-$089BC = 00000000  [SE3 SH1]
ati-$089C0 = 00000000  [SE3 SH1]
ati-$098F0 = 00000000
ati-$098F4 = 00000000
ati-$098F8 = 00000000
ati-$098FC = 00000000
ati-$09B7C = 00000000
ati-$30800 = 40030100
ati-GCKSMCIND-0003F000 = 00000001
ati-GCKSMCIND-0003F004 = 00000000
ati-GCKSMCIND-0003F008 = 00000000
ati-GCKSMCIND-0003F00C = 00000000
ati-GCKSMCIND-0003F010 = 0001E083  [SCLK DPM]
ati-GCKSMCIND-0003F014 = 00000000
ati-GCKSMCIND-0003F018 = 02C4029C
ati-GCKSMCIND-0003F01C = 02D20342
ati-GCKSMCIND-0003F020 = 036E038A
ati-GCKSMCIND-0003F024 = 03A903C7
ati-GCKSMCIND-0003F028 = 02B30291
ati-GCKSMCIND-0003F02C = 02CE0343
ati-GCKSMCIND-0003F030 = 0370038D
ati-GCKSMCIND-0003F034 = 03AD03CC
ati-GCKSMCIND-0003F038 = 02A30287
ati-GCKSMCIND-0003F03C = 02CA0344
ati-GCKSMCIND-0003F040 = 03730391
ati-GCKSMCIND-0003F044 = 03B203D2
ati-GCKSMCIND-0003F048 = 0292027C
ati-GCKSMCIND-0003F04C = 02C60345
ati-GCKSMCIND-0003F050 = 03760395
ati-GCKSMCIND-0003F054 = 03B703D7
ati-GCKSMCIND-0003F058 = 02820272
ati-GCKSMCIND-0003F05C = 02C20347
ati-GCKSMCIND-0003F060 = 03790399
ati-GCKSMCIND-0003F064 = 03BC03DD
ati-GCKSMCIND-0003F068 = 02720268
ati-GCKSMCIND-0003F06C = 02BE0348
ati-GCKSMCIND-0003F070 = 037B039C
ati-GCKSMCIND-0003F074 = 03C003E3
ati-GCKSMCIND-0003F078 = 0261025D
ati-GCKSMCIND-0003F07C = 02BA0349
ati-GCKSMCIND-0003F080 = 037E03A0
ati-GCKSMCIND-0003F084 = 03C503E8
ati-GCKSMCIND-0003F088 = 02510253
ati-GCKSMCIND-0003F08C = 02B6034B
ati-GCKSMCIND-0003F090 = 038103A4
ati-GCKSMCIND-0003F094 = 03CA03EE
ati-GCKSMCIND-0003F098 = 02410248
ati-GCKSMCIND-0003F09C = 02B3034C
ati-GCKSMCIND-0003F0A0 = 038403A8
ati-GCKSMCIND-0003F0A4 = 03CF03F4
ati-GCKSMCIND-0003F0A8 = 0230023E
ati-GCKSMCIND-0003F0AC = 02AF034D
ati-GCKSMCIND-0003F0B0 = 038603AC
ati-GCKSMCIND-0003F0B4 = 03D303F9
ati-GCKSMCIND-0003F0B8 = 02200234
ati-GCKSMCIND-0003F0BC = 02AB034E
ati-GCKSMCIND-0003F0C0 = 038903AF
ati-GCKSMCIND-0003F0C4 = 03D803FF
ati-GCKSMCIND-0003F0C8 = 00000000
ati-GCKSMCIND-0003F0CC = 00000000
ati-GCKSMCIND-0003F0D0 = 00000000
ati-GCKSMCIND-0003F0D4 = 00000000
ati-GCKSMCIND-0003F0D8 = 00000000
ati-GCKSMCIND-0003F0DC = 00090012
ati-GCKSMCIND-0003F0E0 = 00140016
ati-GCKSMCIND-0003F0E4 = 00170019
ati-GCKSMCIND-0003F0E8 = 00590038
ati-GCKSMCIND-0003F0EC = 002C0034
ati-GCKSMCIND-0003F0F0 = 003A003D
ati-GCKSMCIND-0003F0F4 = 00410045
ati-GCKSMCIND-0003F0F8 = 00000A00
ati-GCKSMCIND-0003F0FC = 14001E00
ati-GCKSMCIND-0003F100 = 28003200
ati-GCKSMCIND-0003F104 = 3C004600
ati-GCKSMCIND-0003F108 = 50005A00
ati-GCKSMCIND-0003F10C = 64000000
ati-GCKSMCIND-0003F110 = 0B000000
ati-GCKSMCIND-0003F114 = 09090304
ati-GCKSMCIND-0003F118 = 0B0E0B1F
ati-GCKSMCIND-0003F11C = 02000000
ati-GCKSMCIND-0003F120 = 09080304
ati-GCKSMCIND-0003F124 = 050A081F
ati-GCKSMCIND-0003F128 = 00000000
ati-GCKSMCIND-0003F12C = 09080304
ati-GCKSMCIND-0003F130 = 0309061F
ati-GCKSMCIND-0003F134 = 00000000
ati-GCKSMCIND-0003F138 = 00000000
ati-GCKSMCIND-0003F13C = 00000000
ati-GCKSMCIND-0003F140 = 00000000
ati-GCKSMCIND-0003F144 = 13120709
ati-GCKSMCIND-0003F148 = 161E183F
ati-GCKSMCIND-0003F14C = 06000000
ati-GCKSMCIND-0003F150 = 13100608
ati-GCKSMCIND-0003F154 = 0B151140
ati-GCKSMCIND-0003F158 = 00000000
ati-GCKSMCIND-0003F15C = 13100608
ati-GCKSMCIND-0003F160 = 07130E40
ati-GCKSMCIND-0003F164 = 00000000
ati-GCKSMCIND-0003F168 = 00000000
ati-GCKSMCIND-0003F16C = 00000000
ati-GCKSMCIND-0003F170 = 00000000
ati-GCKSMCIND-0003F174 = 1D1B0B0D
ati-GCKSMCIND-0003F178 = 222F2661
ati-GCKSMCIND-0003F17C = 09000000
ati-GCKSMCIND-0003F180 = 1D19090C
ati-GCKSMCIND-0003F184 = 11201A63
ati-GCKSMCIND-0003F188 = 03000000
ati-GCKSMCIND-0003F18C = 1D19090C
ati-GCKSMCIND-0003F190 = 0B1E1563
ati-GCKSMCIND-0003F194 = 00000000
ati-GCKSMCIND-0003F198 = 00000000
ati-GCKSMCIND-0003F19C = 00000000
ati-GCKSMCIND-0003F1A0 = 00000000
ati-GCKSMCIND-0003F1A4 = 25230E11
ati-GCKSMCIND-0003F1A8 = 2B3C307C
ati-GCKSMCIND-0003F1AC = 0B000000
ati-GCKSMCIND-0003F1B0 = 25200B10
ati-GCKSMCIND-0003F1B4 = 162A227E
ati-GCKSMCIND-0003F1B8 = 04000000
ati-GCKSMCIND-0003F1BC = 25200B10
ati-GCKSMCIND-0003F1C0 = 0E261C7E
ati-GCKSMCIND-0003F1C4 = 00000000
ati-GCKSMCIND-0003F1C8 = 00000000
ati-GCKSMCIND-0003F1CC = 00000000
ati-GCKSMCIND-0003F1D0 = 00000000
ati-GCKSMCIND-0003F1D4 = 28250F12
ati-GCKSMCIND-0003F1D8 = 2E403384
ati-GCKSMCIND-0003F1DC = 0C000000
ati-GCKSMCIND-0003F1E0 = 27220C11
ati-GCKSMCIND-0003F1E4 = 172C2486
ati-GCKSMCIND-0003F1E8 = 04000000
ati-GCKSMCIND-0003F1EC = 27220C11
ati-GCKSMCIND-0003F1F0 = 0E291D86
ati-GCKSMCIND-0003F1F4 = 00000000
ati-GCKSMCIND-0003F1F8 = 00000000
ati-GCKSMCIND-0003F1FC = 00000000
ati-GCKSMCIND-0003F200 = 00000000
ati-GCKSMCIND-0003F204 = 29261013
ati-GCKSMCIND-0003F208 = 30423588
ati-GCKSMCIND-0003F20C = 0C000000
ati-GCKSMCIND-0003F210 = 29230C11
ati-GCKSMCIND-0003F214 = 182E258A
ati-GCKSMCIND-0003F218 = 05000000
ati-GCKSMCIND-0003F21C = 29230C11
ati-GCKSMCIND-0003F220 = 0F2A1F8B
ati-GCKSMCIND-0003F224 = 01000000
ati-GCKSMCIND-0003F228 = 00000000
ati-GCKSMCIND-0003F22C = 00000000
ati-GCKSMCIND-0003F230 = 00000000
ati-GCKSMCIND-0003F234 = 2B271013
ati-GCKSMCIND-0003F238 = 3144378D
ati-GCKSMCIND-0003F23C = 0D000000
ati-GCKSMCIND-0003F240 = 2A250D12
ati-GCKSMCIND-0003F244 = 1930268F
ati-GCKSMCIND-0003F248 = 05000000
ati-GCKSMCIND-0003F24C = 2A250D12
ati-GCKSMCIND-0003F250 = 0F2C2090
ati-GCKSMCIND-0003F254 = 01000000
ati-GCKSMCIND-0003F258 = 00000000
ati-GCKSMCIND-0003F25C = 00000000
ati-GCKSMCIND-0003F260 = 00000000
ati-GCKSMCIND-0003F264 = 2C281114
ati-GCKSMCIND-0003F268 = 33463991
ati-GCKSMCIND-0003F26C = 0D000000
ati-GCKSMCIND-0003F270 = 2B260D13
ati-GCKSMCIND-0003F274 = 19312793
ati-GCKSMCIND-0003F278 = 05000000
ati-GCKSMCIND-0003F27C = 2B260D13
ati-GCKSMCIND-0003F280 = 102D2194
ati-GCKSMCIND-0003F284 = 01000000
ati-GCKSMCIND-0003F288 = 00000000
ati-GCKSMCIND-0003F28C = 00000000
ati-GCKSMCIND-0003F290 = 00000000
ati-GCKSMCIND-0003F294 = 00000000
ati-GCKSMCIND-0003F298 = 000003FF
ati-GCKSMCIND-0003F29C = FFFFFC00
ati-GCKSMCIND-0003F2A0 = 00000003
ati-GCKSMCIND-0003F2A4 = 0000000A
ati-GCKSMCIND-0003F2A8 = 00000400
ati-GCKSMCIND-0003F2AC = 00000007
ati-GCKSMCIND-0003F2B0 = 000000FF
ati-GCKSMCIND-0003F2B4 = 00000008
ati-GCKSMCIND-0003F2B8 = 00000000
ati-GCKSMCIND-0003F2BC = 000003FF
ati-GCKSMCIND-0003F2C0 = FFFFFC00
ati-GCKSMCIND-0003F2C4 = 00000003
ati-GCKSMCIND-0003F2C8 = 0000000A
ati-GCKSMCIND-0003F2CC = 00000400
ati-GCKSMCIND-0003F2D0 = 00000007
ati-GCKSMCIND-0003F2D4 = 000000FF
ati-GCKSMCIND-0003F2D8 = 00000008
ati-GCKSMCIND-0003F2DC = 00000000
ati-GCKSMCIND-0003F2E0 = 000003FF
ati-GCKSMCIND-0003F2E4 = FFFFFC00
ati-GCKSMCIND-0003F2E8 = 00000003
ati-GCKSMCIND-0003F2EC = 0000000A
ati-GCKSMCIND-0003F2F0 = 00000400
ati-GCKSMCIND-0003F2F4 = 00000007
ati-GCKSMCIND-0003F2F8 = 000000FF
ati-GCKSMCIND-0003F2FC = 00000008
ati-GCKSMCIND-0003F300 = 00000005
ati-GCKSMCIND-0003F304 = 05030001
ati-GCKSMCIND-0003F308 = 00108002
ati-GCKSMCIND-0003F30C = 00000000
ati-GCKSMCIND-0003F310 = 0C800000
ati-GCKSMCIND-0003F314 = 0D480100
ati-GCKSMCIND-0003F318 = 0E100200
ati-GCKSMCIND-0003F31C = 0ED80300
ati-GCKSMCIND-0003F320 = 00000000
ati-GCKSMCIND-0003F324 = 00000000
ati-GCKSMCIND-0003F328 = 00000000
ati-GCKSMCIND-0003F32C = 00000000
ati-GCKSMCIND-0003F330 = 00000000
ati-GCKSMCIND-0003F334 = F8F8F8F8
ati-GCKSMCIND-0003F338 = F8F8F8F8
ati-GCKSMCIND-0003F33C = F8F8F8F8
ati-GCKSMCIND-0003F340 = F8F8F8F8
ati-GCKSMCIND-0003F344 = F8F8F8F8
ati-GCKSMCIND-0003F348 = F8F8F8F8
ati-GCKSMCIND-0003F34C = F8F8F8F8
ati-GCKSMCIND-0003F350 = F8F8F8F8
ati-GCKSMCIND-0003F354 = F8F8F8F8
ati-GCKSMCIND-0003F358 = F8F8F8F8
ati-GCKSMCIND-0003F35C = F8F8F8F8
ati-GCKSMCIND-0003F360 = F8F8F8F8
ati-GCKSMCIND-0003F364 = 08030201
ati-GCKSMCIND-0003F368 = 08080008
ati-GCKSMCIND-0003F36C = 11010000
ati-GCKSMCIND-0003F370 = 01060300
ati-GCKSMCIND-0003F374 = 38003700
ati-GCKSMCIND-0003F378 = 12C00000
ati-GCKSMCIND-0003F37C = 00000000
ati-GCKSMCIND-0003F380 = 46400BB8  [SCLK DPM0 / MinVddc = 0.75000 V]
ati-GCKSMCIND-0003F384 = 0003001E
ati-GCKSMCIND-0003F388 = 00000000  [SCLK DPM0 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F38C = 00000000  [SCLK DPM0 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F390 = 00000000
ati-GCKSMCIND-0003F394 = 00000000
ati-GCKSMCIND-0003F398 = 00000001  [SCLK DPM0 / SclkDid = 0]
ati-GCKSMCIND-0003F39C = 00050000
ati-GCKSMCIND-0003F3A0 = 00007530  [SCLK DPM0 / SclkFreq = 300 MHz]
ati-GCKSMCIND-0003F3A4 = 00300000  [SCLK DPM0 / SclkSetting_Fcw = 48.00000]
ati-GCKSMCIND-0003F3A8 = 00260001
ati-GCKSMCIND-0003F3AC = 0400028F
ati-GCKSMCIND-0003F3B0 = FFFF002F  [SCLK DPM0 / SclkSetting_Fcw1_int = 47]
ati-GCKSMCIND-0003F3B4 = C8330009  [SCLK DPM0 / SclkSetting_Fcw1_frac = 0.78203]
ati-GCKSMCIND-0003F3B8 = 46400C04  [SCLK DPM1 / MinVddc = 0.76900 V]
ati-GCKSMCIND-0003F3BC = 0104001E
ati-GCKSMCIND-0003F3C0 = 00000000  [SCLK DPM1 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F3C4 = 00000000  [SCLK DPM1 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F3C8 = 00000000
ati-GCKSMCIND-0003F3CC = 00000000
ati-GCKSMCIND-0003F3D0 = 00000001  [SCLK DPM1 / SclkDid = 0]
ati-GCKSMCIND-0003F3D4 = 00050000
ati-GCKSMCIND-0003F3D8 = 0000EA60  [SCLK DPM1 / SclkFreq = 600 MHz]
ati-GCKSMCIND-0003F3DC = 00300000  [SCLK DPM1 / SclkSetting_Fcw = 48.00000]
ati-GCKSMCIND-0003F3E0 = 00260101
ati-GCKSMCIND-0003F3E4 = 0400028F
ati-GCKSMCIND-0003F3E8 = FFFF002F  [SCLK DPM1 / SclkSetting_Fcw1_int = 47]
ati-GCKSMCIND-0003F3EC = C8330009  [SCLK DPM1 / SclkSetting_Fcw1_frac = 0.78203]
ati-GCKSMCIND-0003F3F0 = 46400E28  [SCLK DPM2 / MinVddc = 0.90600 V]
ati-GCKSMCIND-0003F3F4 = 0100001E
ati-GCKSMCIND-0003F3F8 = 00000000  [SCLK DPM2 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F3FC = 00000000  [SCLK DPM2 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F400 = 00000000
ati-GCKSMCIND-0003F404 = 00000000
ati-GCKSMCIND-0003F408 = 00000001  [SCLK DPM2 / SclkDid = 0]
ati-GCKSMCIND-0003F40C = 00050000
ati-GCKSMCIND-0003F410 = 00016698  [SCLK DPM2 / SclkFreq = 918 MHz]
ati-GCKSMCIND-0003F414 = 0024B851  [SCLK DPM2 / SclkSetting_Fcw = 36.71999]
ati-GCKSMCIND-0003F418 = 001E0201
ati-GCKSMCIND-0003F41C = 040001B8
ati-GCKSMCIND-0003F420 = FFFF0024  [SCLK DPM2 / SclkSetting_Fcw1_int = 36]
ati-GCKSMCIND-0003F424 = 8CEA0007  [SCLK DPM2 / SclkSetting_Fcw1_frac = 0.55045]
ati-GCKSMCIND-0003F428 = 476C11AC  [SCLK DPM3 / MinVddc = 1.13100 V]
ati-GCKSMCIND-0003F42C = 0100001E
ati-GCKSMCIND-0003F430 = 00000000  [SCLK DPM3 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F434 = 00000000  [SCLK DPM3 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F438 = 00000000
ati-GCKSMCIND-0003F43C = 00000000
ati-GCKSMCIND-0003F440 = 00000001  [SCLK DPM3 / SclkDid = 0]
ati-GCKSMCIND-0003F444 = 00050000
ati-GCKSMCIND-0003F448 = 0001C7DC  [SCLK DPM3 / SclkFreq = 1167 MHz]
ati-GCKSMCIND-0003F44C = 002EAE14  [SCLK DPM3 / SclkSetting_Fcw = 46.67999]
ati-GCKSMCIND-0003F450 = 00250201
ati-GCKSMCIND-0003F454 = 0400027A
ati-GCKSMCIND-0003F458 = FFFF002E  [SCLK DPM3 / SclkSetting_Fcw1_int = 46]
ati-GCKSMCIND-0003F45C = 76470009  [SCLK DPM3 / SclkSetting_Fcw1_frac = 0.46202]
ati-GCKSMCIND-0003F460 = 476C11F8  [SCLK DPM4 / MinVddc = 1.15000 V]
ati-GCKSMCIND-0003F464 = 0100001E
ati-GCKSMCIND-0003F468 = 00000000  [SCLK DPM4 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F46C = 00000000  [SCLK DPM4 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F470 = 00000000
ati-GCKSMCIND-0003F474 = 00000000
ati-GCKSMCIND-0003F478 = 00000001  [SCLK DPM4 / SclkDid = 0]
ati-GCKSMCIND-0003F47C = 00050000
ati-GCKSMCIND-0003F480 = 0001E3FC  [SCLK DPM4 / SclkFreq = 1239 MHz]
ati-GCKSMCIND-0003F484 = 00318F5C  [SCLK DPM4 / SclkSetting_Fcw = 49.56000]
ati-GCKSMCIND-0003F488 = 00270201
ati-GCKSMCIND-0003F48C = 040002B4
ati-GCKSMCIND-0003F490 = FFFF0031  [SCLK DPM4 / SclkSetting_Fcw1_int = 49]
ati-GCKSMCIND-0003F494 = 515B000A  [SCLK DPM4 / SclkSetting_Fcw1_frac = 0.31779]
ati-GCKSMCIND-0003F498 = 476C11F8  [SCLK DPM5 / MinVddc = 1.15000 V]
ati-GCKSMCIND-0003F49C = 0100001E
ati-GCKSMCIND-0003F4A0 = 00000000  [SCLK DPM5 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F4A4 = 00000000  [SCLK DPM5 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F4A8 = 00000000
ati-GCKSMCIND-0003F4AC = 00000000
ati-GCKSMCIND-0003F4B0 = 00000001  [SCLK DPM5 / SclkDid = 0]
ati-GCKSMCIND-0003F4B4 = 00050000
ati-GCKSMCIND-0003F4B8 = 0001F4C8  [SCLK DPM5 / SclkFreq = 1282 MHz]
ati-GCKSMCIND-0003F4BC = 003347AE  [SCLK DPM5 / SclkSetting_Fcw = 51.28000]
ati-GCKSMCIND-0003F4C0 = 00290201
ati-GCKSMCIND-0003F4C4 = 040002A1
ati-GCKSMCIND-0003F4C8 = FFFF0033  [SCLK DPM5 / SclkSetting_Fcw1_int = 51]
ati-GCKSMCIND-0003F4CC = 09AD000A  [SCLK DPM5 / SclkSetting_Fcw1_frac = 0.03780]
ati-GCKSMCIND-0003F4D0 = 476C11F8  [SCLK DPM6 / MinVddc = 1.15000 V]
ati-GCKSMCIND-0003F4D4 = 0100001E
ati-GCKSMCIND-0003F4D8 = 00000000  [SCLK DPM6 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F4DC = 00000000  [SCLK DPM6 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F4E0 = 00000000
ati-GCKSMCIND-0003F4E4 = 00000000
ati-GCKSMCIND-0003F4E8 = 00000101  [SCLK DPM6 / SclkDid = 0]
ati-GCKSMCIND-0003F4EC = 00050000
ati-GCKSMCIND-0003F4F0 = 000205F8  [SCLK DPM6 / SclkFreq = 1326 MHz]
ati-GCKSMCIND-0003F4F4 = 00350A3D  [SCLK DPM6 / SclkSetting_Fcw = 53.03999]
ati-GCKSMCIND-0003F4F8 = 002A0201
ati-GCKSMCIND-0003F4FC = 040002D3
ati-GCKSMCIND-0003F500 = FFFF0034  [SCLK DPM6 / SclkSetting_Fcw1_int = 52]
ati-GCKSMCIND-0003F504 = CC3C000A  [SCLK DPM6 / SclkSetting_Fcw1_frac = 0.79779]
ati-GCKSMCIND-0003F508 = 476C11F8  [SCLK DPM7 / MinVddc = 1.15000 V]
ati-GCKSMCIND-0003F50C = 0100001E
ati-GCKSMCIND-0003F510 = 00000000  [SCLK DPM7 / CgSpllFuncCntl3]
ati-GCKSMCIND-0003F514 = 00000000  [SCLK DPM7 / CgSpllFuncCntl4]
ati-GCKSMCIND-0003F518 = 00000000
ati-GCKSMCIND-0003F51C = 00000000
ati-GCKSMCIND-0003F520 = 00000101  [SCLK DPM7 / SclkDid = 0]
ati-GCKSMCIND-0003F524 = 00050000
ati-GCKSMCIND-0003F528 = 00021598  [SCLK DPM7 / SclkFreq = 1366 MHz]
ati-GCKSMCIND-0003F52C = 0036A3D7  [SCLK DPM7 / SclkSetting_Fcw = 54.64000]
ati-GCKSMCIND-0003F530 = 002B0201
ati-GCKSMCIND-0003F534 = 040002FA
ati-GCKSMCIND-0003F538 = FFFF0036  [SCLK DPM7 / SclkSetting_Fcw1_int = 54]
ati-GCKSMCIND-0003F53C = 5FA3000B  [SCLK DPM7 / SclkSetting_Fcw1_frac = 0.37358]
ati-GCKSMCIND-0003F540 = 46400BB8
ati-GCKSMCIND-0003F544 = 00000000
ati-GCKSMCIND-0003F548 = 00007530  [MCLK ACPI / MclkFreq = 300 MHz]
ati-GCKSMCIND-0003F54C = 00000000
ati-GCKSMCIND-0003F550 = 00640000
ati-GCKSMCIND-0003F554 = 001E0000
ati-GCKSMCIND-0003F558 = 46400BB8
ati-GCKSMCIND-0003F55C = 00001838
ati-GCKSMCIND-0003F560 = 00007530  [MCLK DPM0 / MclkFreq = 300 MHz]
ati-GCKSMCIND-0003F564 = 01010000
ati-GCKSMCIND-0003F568 = 0A100000
ati-GCKSMCIND-0003F56C = 002D0000
ati-GCKSMCIND-0003F570 = 46A40C80
ati-GCKSMCIND-0003F574 = 00001838
ati-GCKSMCIND-0003F578 = 000186A0  [MCLK DPM1 / MclkFreq = 1000 MHz]
ati-GCKSMCIND-0003F57C = 00010000
ati-GCKSMCIND-0003F580 = 0A100000
ati-GCKSMCIND-0003F584 = 002D0000
ati-GCKSMCIND-0003F588 = 476C0ED8
ati-GCKSMCIND-0003F58C = 00001838
ati-GCKSMCIND-0003F590 = 00030D40  [MCLK DPM2 / MclkFreq = 2000 MHz]
ati-GCKSMCIND-0003F594 = 00010100
ati-GCKSMCIND-0003F598 = 0A3C0000
ati-GCKSMCIND-0003F59C = 00190100
ati-GCKSMCIND-0003F5A0 = 00000000
ati-GCKSMCIND-0003F5A4 = 00000000
ati-GCKSMCIND-0003F5A8 = 00000000  [MCLK DPM3 / MclkFreq = 0 MHz]
ati-GCKSMCIND-0003F5AC = 00000000
ati-GCKSMCIND-0003F5B0 = 00000000
ati-GCKSMCIND-0003F5B4 = 00000000
ati-GCKSMCIND-0003F5B8 = 00040114
ati-GCKSMCIND-0003F5BC = 00000005
ati-GCKSMCIND-0003F5C0 = 0000001E
ati-GCKSMCIND-0003F5C4 = 007F0000
ati-GCKSMCIND-0003F5C8 = 02040114
ati-GCKSMCIND-0003F5CC = 00000005
ati-GCKSMCIND-0003F5D0 = 0000001E
ati-GCKSMCIND-0003F5D4 = 007F0000
ati-GCKSMCIND-0003F5D8 = 00040114
ati-GCKSMCIND-0003F5DC = 00000005
ati-GCKSMCIND-0003F5E0 = 0000001E
ati-GCKSMCIND-0003F5E4 = 00000000
ati-GCKSMCIND-0003F5E8 = 00000000
ati-GCKSMCIND-0003F5EC = 00000000
ati-GCKSMCIND-0003F5F0 = 00000000
ati-GCKSMCIND-0003F5F4 = 00000000
ati-GCKSMCIND-0003F5F8 = 00000000
ati-GCKSMCIND-0003F5FC = 00000000
ati-GCKSMCIND-0003F600 = 00000000
ati-GCKSMCIND-0003F604 = 00000000
ati-GCKSMCIND-0003F608 = 00000000
ati-GCKSMCIND-0003F60C = 00000000
ati-GCKSMCIND-0003F610 = 00000000
ati-GCKSMCIND-0003F614 = 00000000
ati-GCKSMCIND-0003F618 = 00000000
ati-GCKSMCIND-0003F61C = 00000000
ati-GCKSMCIND-0003F620 = 00000000
ati-GCKSMCIND-0003F624 = 00000000
ati-GCKSMCIND-0003F628 = 00000000
ati-GCKSMCIND-0003F62C = 00000000
ati-GCKSMCIND-0003F630 = 00000000
ati-GCKSMCIND-0003F634 = 00000000
ati-GCKSMCIND-0003F638 = 00000000
ati-GCKSMCIND-0003F63C = 46400BB8
ati-GCKSMCIND-0003F640 = 00000000
ati-GCKSMCIND-0003F644 = 00000000
ati-GCKSMCIND-0003F648 = 00000000
ati-GCKSMCIND-0003F64C = 00000000
ati-GCKSMCIND-0003F650 = 00007530
ati-GCKSMCIND-0003F654 = 00300000
ati-GCKSMCIND-0003F658 = 00260001
ati-GCKSMCIND-0003F65C = 0400028F
ati-GCKSMCIND-0003F660 = FFFF002F
ati-GCKSMCIND-0003F664 = C8330009
ati-GCKSMCIND-0003F668 = 000124F8
ati-GCKSMCIND-0003F66C = 0000E290
ati-GCKSMCIND-0003F670 = 46400C80
ati-GCKSMCIND-0003F674 = 14190000
ati-GCKSMCIND-0003F678 = 00013880
ati-GCKSMCIND-0003F67C = 0000F618
ati-GCKSMCIND-0003F680 = 46400D48
ati-GCKSMCIND-0003F684 = 12170000
ati-GCKSMCIND-0003F688 = 00014C08
ati-GCKSMCIND-0003F68C = 000109A0
ati-GCKSMCIND-0003F690 = 46400E10
ati-GCKSMCIND-0003F694 = 11160000
ati-GCKSMCIND-0003F698 = 00015BA8
ati-GCKSMCIND-0003F69C = 00011D28
ati-GCKSMCIND-0003F6A0 = 46400ED8
ati-GCKSMCIND-0003F6A4 = 11140000
ati-GCKSMCIND-0003F6A8 = 00016760
ati-GCKSMCIND-0003F6AC = 00012CC8
ati-GCKSMCIND-0003F6B0 = 46400FA0
ati-GCKSMCIND-0003F6B4 = 10130000
ati-GCKSMCIND-0003F6B8 = 00017318
ati-GCKSMCIND-0003F6BC = 00013880
ati-GCKSMCIND-0003F6C0 = 46A41068
ati-GCKSMCIND-0003F6C4 = 10120000
ati-GCKSMCIND-0003F6C8 = 00017ED0
ati-GCKSMCIND-0003F6CC = 00014438
ati-GCKSMCIND-0003F6D0 = 47081130
ati-GCKSMCIND-0003F6D4 = 0F120000
ati-GCKSMCIND-0003F6D8 = 000186A0
ati-GCKSMCIND-0003F6DC = 00014FF0
ati-GCKSMCIND-0003F6E0 = 476C11F8
ati-GCKSMCIND-0003F6E4 = 0F110000
ati-GCKSMCIND-0003F6E8 = 0000F618
ati-GCKSMCIND-0003F6EC = 46400C80
ati-GCKSMCIND-0003F6F0 = 17000000
ati-GCKSMCIND-0003F6F4 = 00010D88
ati-GCKSMCIND-0003F6F8 = 46400D48
ati-GCKSMCIND-0003F6FC = 15000000
ati-GCKSMCIND-0003F700 = 000124F8
ati-GCKSMCIND-0003F704 = 46400E10
ati-GCKSMCIND-0003F708 = 14000000
ati-GCKSMCIND-0003F70C = 00013C68
ati-GCKSMCIND-0003F710 = 46400ED8
ati-GCKSMCIND-0003F714 = 12000000
ati-GCKSMCIND-0003F718 = 00014FF0
ati-GCKSMCIND-0003F71C = 46400FA0
ati-GCKSMCIND-0003F720 = 11000000
ati-GCKSMCIND-0003F724 = 00016378
ati-GCKSMCIND-0003F728 = 46A41068
ati-GCKSMCIND-0003F72C = 10000000
ati-GCKSMCIND-0003F730 = 00017700
ati-GCKSMCIND-0003F734 = 47081130
ati-GCKSMCIND-0003F738 = 0F000000
ati-GCKSMCIND-0003F73C = 000186A0
ati-GCKSMCIND-0003F740 = 476C11F8
ati-GCKSMCIND-0003F744 = 0F000000
ati-GCKSMCIND-0003F748 = 00000000
ati-GCKSMCIND-0003F74C = 00000000
ati-GCKSMCIND-0003F750 = 00000000
ati-GCKSMCIND-0003F754 = 00000000
ati-GCKSMCIND-0003F758 = 00000000
ati-GCKSMCIND-0003F75C = 00000000
ati-GCKSMCIND-0003F760 = 00000000
ati-GCKSMCIND-0003F764 = 00000000
ati-GCKSMCIND-0003F768 = 00000000
ati-GCKSMCIND-0003F76C = 00000000
ati-GCKSMCIND-0003F770 = 00000000
ati-GCKSMCIND-0003F774 = 00000000
ati-GCKSMCIND-0003F778 = 00000000
ati-GCKSMCIND-0003F77C = 00000000
ati-GCKSMCIND-0003F780 = 00000000
ati-GCKSMCIND-0003F784 = 00000000
ati-GCKSMCIND-0003F788 = 00000000
ati-GCKSMCIND-0003F78C = 00000000
ati-GCKSMCIND-0003F790 = 00000000
ati-GCKSMCIND-0003F794 = 00000000
ati-GCKSMCIND-0003F798 = 00000000
ati-GCKSMCIND-0003F79C = 00000000
ati-GCKSMCIND-0003F7A0 = 00000000
ati-GCKSMCIND-0003F7A4 = 00000000
ati-GCKSMCIND-0003F7A8 = 0000DEA8
ati-GCKSMCIND-0003F7AC = 46400C80
ati-GCKSMCIND-0003F7B0 = 1A000000
ati-GCKSMCIND-0003F7B4 = 0000FA00
ati-GCKSMCIND-0003F7B8 = 46400D48
ati-GCKSMCIND-0003F7BC = 17000000
ati-GCKSMCIND-0003F7C0 = 00011170
ati-GCKSMCIND-0003F7C4 = 46400E10
ati-GCKSMCIND-0003F7C8 = 15000000
ati-GCKSMCIND-0003F7CC = 000128E0
ati-GCKSMCIND-0003F7D0 = 46400ED8
ati-GCKSMCIND-0003F7D4 = 13000000
ati-GCKSMCIND-0003F7D8 = 00013C68
ati-GCKSMCIND-0003F7DC = 46400FA0
ati-GCKSMCIND-0003F7E0 = 12000000
ati-GCKSMCIND-0003F7E4 = 00014C08
ati-GCKSMCIND-0003F7E8 = 46A41068
ati-GCKSMCIND-0003F7EC = 11000000
ati-GCKSMCIND-0003F7F0 = 000157C0
ati-GCKSMCIND-0003F7F4 = 47081130
ati-GCKSMCIND-0003F7F8 = 11000000
ati-GCKSMCIND-0003F7FC = 00016378
ati-GCKSMCIND-0003F800 = 476C11F8
ati-GCKSMCIND-0003F804 = 10000000
ati-GCKSMCIND-0003F808 = 00000000
ati-GCKSMCIND-0003F80C = 00000000
ati-GCKSMCIND-0003F810 = 00190403
ati-GCKSMCIND-0003F814 = 007F0000
ati-GCKSMCIND-0003F818 = 00000001
ati-GCKSMCIND-0003F81C = 01010101
ati-GCKSMCIND-0003F820 = 02020203
ati-GCKSMCIND-0003F824 = 03030303
ati-GCKSMCIND-0003F828 = 02020203
ati-GCKSMCIND-0003F82C = 03030303
ati-GCKSMCIND-0003F830 = 00000000
ati-GCKSMCIND-0003F834 = 00000000
ati-GCKSMCIND-0003F838 = 00004000
ati-GCKSMCIND-0003F83C = 00000000
ati-GCKSMCIND-0003F840 = 00100000
ati-GCKSMCIND-0003F844 = 00000002
ati-GCKSMCIND-0003F848 = 00008000
ati-GCKSMCIND-0003F84C = 00000000
ati-GCKSMCIND-0003F850 = 00000000
ati-GCKSMCIND-0003F854 = 00000000
ati-GCKSMCIND-0003F858 = 00000000
ati-GCKSMCIND-0003F85C = 00000000
ati-GCKSMCIND-0003F860 = 00000000
ati-GCKSMCIND-0003F864 = 00000000
ati-GCKSMCIND-0003F868 = 00000000
ati-GCKSMCIND-0003F86C = 00000000
ati-GCKSMCIND-0003F870 = 00000000
ati-GCKSMCIND-0003F874 = 00000000
ati-GCKSMCIND-0003F878 = 00000000
ati-GCKSMCIND-0003F87C = 00000000
ati-GCKSMCIND-0003F880 = 00000000
ati-GCKSMCIND-0003F884 = 00000000
ati-GCKSMCIND-0003F888 = 00000000
ati-GCKSMCIND-0003F88C = 00000000
ati-GCKSMCIND-0003F890 = 00000000
ati-GCKSMCIND-0003F894 = 00000000
ati-GCKSMCIND-0003F898 = 00000000
ati-GCKSMCIND-0003F89C = 00000000
ati-GCKSMCIND-0003F8A0 = 00000000
ati-GCKSMCIND-0003F8A4 = 00000000
ati-GCKSMCIND-0003F8A8 = 00000000
ati-GCKSMCIND-0003F8AC = 00000000
ati-GCKSMCIND-0003F8B0 = 00000000
ati-GCKSMCIND-0003F8B4 = 00000000
ati-GCKSMCIND-0003F8B8 = 00000000
ati-GCKSMCIND-0003F8BC = 00000000
ati-GCKSMCIND-0003F8C0 = 00010101
ati-GCKSMCIND-0003F8C4 = 01015A00
ati-GCKSMCIND-0003F8C8 = 59000001
ati-GCKSMCIND-0003F8CC = 18380101
ati-GCKSMCIND-0003F8D0 = 00000000
ati-GCKSMCIND-0003F8D4 = 02010000
ati-GCKSMCIND-0003F8D8 = 00057F11
ati-GCKSMCIND-0003F8DC = 00000000
ati-GCKSMCIND-0003F8E0 = 48804880
ati-GCKSMCIND-0003F8E4 = 00000000
ati-GCKSMCIND-0003F8E8 = 00790253
ati-GCKSMCIND-0003F8EC = 025D00AE
ati-GCKSMCIND-0003F8F0 = 00720080
ati-GCKSMCIND-0003F8F4 = 00830086
ati-GCKSMCIND-0003F8F8 = 006F00C8
ati-GCKSMCIND-0003F8FC = 00C900C9
ati-GCKSMCIND-0003F900 = 002F004D
ati-GCKSMCIND-0003F904 = 0061017C
ati-GCKSMCIND-0003F908 = 01720180
ati-GCKSMCIND-0003F90C = 01BC01B3
ati-GCKSMCIND-0003F910 = 01BD0206
ati-GCKSMCIND-0003F914 = 02000203
ati-GCKSMCIND-0003F918 = 025D025A
ati-GCKSMCIND-0003F91C = 025502C3
ati-GCKSMCIND-0003F920 = 02C502B4
ati-GCKSMCIND-0003F924 = 5A006900
ati-GCKSMCIND-0003F928 = 0E100D48
ati-GCKSMCIND-0003F92C = 18001800
ati-GCKSMCIND-0003F930 = 00000000
ati-GCKSMCIND-0003F934 = 00000000
ati-GCKSMCIND-0003F938 = 00FE0000
ati-GCKSMCIND-0003F93C = 0509121C
ati-GCKSMCIND-0003F940 = 2124272B
ati-GCKSMCIND-0003F944 = 00000000
ati-GCKSMCIND-0003F948 = 00000000
ati-GCKSMCIND-0003F94C = 00000000
ati-GCKSMCIND-0003F950 = 00000000
ati-GCKSMCIND-0003F954 = 00000000
ati-GCKSMCIND-0003F958 = 00000000
ati-GCKSMCIND-0003F95C = 00000000
ati-GCKSMCIND-0003F960 = 00000000
ati-GCKSMCIND-0003F964 = 00000000
ati-GCKSMCIND-0003F968 = 00000000
ati-GCKSMCIND-0003F96C = 00000000
ati-GCKSMCIND-0003F970 = 00000000
ati-GCKSMCIND-0003F974 = 00000002
ati-GCKSMCIND-0003F978 = 0104001E
ati-GCKSMCIND-0003F97C = 003C0000
ati-GCKSMCIND-0003F980 = 0103001E
ati-GCKSMCIND-0003F984 = 003C001E
ati-GCKSMCIND-0003F988 = 0102001E
ati-GCKSMCIND-0003F98C = 003C001E
ati-GCKSMCIND-0003F990 = 0101001E
ati-GCKSMCIND-0003F994 = 0000001E
ati-GCKSMCIND-0003F998 = 00000000
ati-GCKSMCIND-0003F99C = 00000000
ati-GCKSMCIND-0003F9A0 = 00000000
ati-GCKSMCIND-0003F9A4 = 00000000
ati-GCKSMCIND-0003F9A8 = 00000000
ati-GCKSMCIND-0003F9AC = 00000000
ati-GCKSMCIND-0003F9B0 = 00000000
ati-GCKSMCIND-0003F9B4 = 00000000
ati-GCKSMCIND-0003F9B8 = 00000000
ati-GCKSMCIND-0003F9BC = 00030DF3
ati-GCKSMCIND-0003F9C0 = FFFE607F
ati-GCKSMCIND-0003F9C4 = 00000000
ati-GCKSMCIND-0003F9C8 = F843B66B
ati-GCKSMCIND-0003F9CC = 00059CB5
ati-GCKSMCIND-0003F9D0 = FFFF287F
ati-GCKSMCIND-0003F9D4 = 00000000
ati-GCKSMCIND-0003F9D8 = 00000000
ati-GCKSMCIND-0003F9DC = FFFFFFEB  [SCLK DPM]
ati-GCKSMCIND-0003F9E0 = 008A180C  [SCLK DPM]
ati-GCKSMCIND-0003F9E4 = 00000000
ati-GCKSMCIND-0003F9E8 = 00000058
ati-GCKSMCIND-0003F9EC = FF23180C
ati-GCKSMCIND-0003F9F0 = 00000028
ati-GCKSMCIND-0003F9F4 = 0041006D
ati-GCKSMCIND-0003F9F8 = 00110016
ati-GCKSMCIND-0003F9FC = 001B0001
ati-GCKSMCIND-0003FA00 = 00030001
ati-GCKSMCIND-0003FA04 = 00050000
ati-GCKSMCIND-0003FA08 = 00000000
ati-GCKSMCIND-0003FA0C = 0002625A
ati-GCKSMCIND-0003FA10 = 00870000
ati-GCKSMCIND-0003FA14 = 000009C4
ati-GCKSMCIND-0003FA18 = 000003E8
ati-GCKSMCIND-0003FA1C = 00000000
ati-GCKSMCIND-0003FA20 = 00000064
ati-GCKSMCIND-0003FA24 = 000000C7
ati-GCKSMCIND-0003FA28 = 000000FA
ati-GCKSMCIND-0003FA2C = 00000000
ati-GCKSMCIND-0003FA30 = 00000000
ati-GCKSMCIND-0003FA34 = 00000000
ati-GCKSMCIND-0003FA38 = 00000000
ati-GCKSMCIND-0003FA3C = 00000028
ati-GCKSMCIND-0003FA40 = 00001000
ati-GCKSMCIND-0003FA44 = 00030100
ati-GCKSMCIND-0003FA48 = 00000000
ati-GCKSMCIND-0003FA4C = 00000000
ati-GCKSMCIND-0003FA50 = 00000001
ati-GCKSMCIND-0003FA54 = 00000001
ati-GCKSMCIND-0003FA58 = 00000000
ati-GCKSMCIND-0003FA5C = C0040003
ati-GCKSMCIND-0003FA60 = 00FF0000
ati-GCKSMCIND-0003FA64 = 00000000
ati-GCKSMCIND-0003FA68 = 00000000
ati-GCKSMCIND-0003FA6C = 00000000
ati-GCKSMCIND-0003FA70 = 00000000
ati-GCKSMCIND-0003FA74 = 00000000
ati-GCKSMCIND-0003FA78 = 0003C840
ati-GCKSMCIND-0003FA7C = BD0CD3CA
ati-GCKSMCIND-0003FA80 = 000005FE
ati-GCKSMCIND-0003FA84 = 00000000
ati-GCKSMCIND-0003FA88 = E0000000
ati-GCKSMCIND-0003FA8C = 00000000
ati-GCKSMCIND-0003FA90 = 00000000
ati-GCKSMCIND-0003FA94 = 00000000
ati-GCKSMCIND-0003FA98 = 00000000
ati-GCKSMCIND-0003FA9C = 00000000
ati-GCKSMCIND-0003FAA0 = 00000000
ati-GCKSMCIND-0003FAA4 = 010F0300
ati-GCKSMCIND-0003FAA8 = 4200FD19
ati-GCKSMCIND-0003FAAC = 05000000
ati-GCKSMCIND-0003FAB0 = 00000000
ati-GCKSMCIND-0003FAB4 = 00000000
ati-GCKSMCIND-0003FAB8 = 00000000
ati-GCKSMCIND-0003FABC = 00000000
ati-GCKSMCIND-0003FAC0 = 00000000
ati-GCKSMCIND-0003FAC4 = 12E40000
ati-GCKSMCIND-0003FAC8 = 00000000
ati-GCKSMCIND-0003FACC = 00000000
ati-GCKSMCIND-0003FAD0 = 00000000
ati-GCKSMCIND-0003FAD4 = 00000000
ati-GCKSMCIND-0003FAD8 = 00000000
ati-GCKSMCIND-0003FADC = 00000000
ati-GCKSMCIND-0003FAE0 = 00006400
ati-GCKSMCIND-0003FAE4 = 00000100
ati-GCKSMCIND-0003FAE8 = 0000204B
ati-GCKSMCIND-0003FAEC = 00000346
ati-GCKSMCIND-0003FAF0 = F6C1180C
ati-GCKSMCIND-0003FAF4 = 000020F4
ati-GCKSMCIND-0003FAF8 = 00000268
ati-GCKSMCIND-0003FAFC = F9CC180C
ati-GCKSMCIND-0003FB00 = 00000000
ati-GCKSMCIND-0003FB04 = 00000000
ati-GCKSMCIND-0003FB08 = 0000180C
ati-GCKSMCIND-0003FB0C = 00000000
ati-GCKSMCIND-0003FB10 = FFFFFFEB
ati-GCKSMCIND-0003FB14 = 008A180C
ati-GCKSMCIND-0003FB18 = 000007C6
ati-GCKSMCIND-0003FB1C = 00000091
ati-GCKSMCIND-0003FB20 = FC88180C
ati-GCKSMCIND-0003FB24 = 00002B96
ati-GCKSMCIND-0003FB28 = 00000600
ati-GCKSMCIND-0003FB2C = E718180C
ati-GCKSMCIND-0003FB30 = 0000EA60
ati-GCKSMCIND-0003FB34 = 0B006400
ati-GCKSMCIND-0003FB38 = 001FFFDF
ati-GCKSMCIND-0003FB3C = 000011CD
ati-GCKSMCIND-0003FB40 = 0000008E
ati-GCKSMCIND-0003FB44 = FB5B180C
ati-GCKSMCIND-0003FB48 = 004E0040
ati-GCKSMCIND-0003FB4C = 006700AC
ati-GCKSMCIND-0003FB50 = 00C600D7
ati-GCKSMCIND-0003FB54 = 00EA00FB
ati-GCKSMCIND-0003FB58 = 00470037
ati-GCKSMCIND-0003FB5C = 00260019
ati-GCKSMCIND-0003FB60 = 00150012
ati-GCKSMCIND-0003FB64 = 0010000E
ati-GCKSMCIND-0003FB68 = 00000000
ati-GCKSMCIND-0003FB6C = 00000000
ati-GCKSMCIND-0003FB70 = 00000000
ati-GCKSMCIND-0003FB74 = 00000000
ati-GCKSMCIND-0003FB78 = 00000129
ati-GCKSMCIND-0003FB7C = 000004A2
ati-GCKSMCIND-0003FB80 = 000001BE
ati-GCKSMCIND-0003FB84 = 001B0BB8
ati-GCKSMCIND-0003FB88 = 00000100
ati-GCKSMCIND-0003FB8C = 00000000
ati-GCKSMCIND-0003FB90 = 00000000
ati-GCKSMCIND-0003FB94 = 003C003F
ati-GCKSMCIND-0003FB98 = 0058007F
ati-GCKSMCIND-0003FB9C = 008D0096
ati-GCKSMCIND-0003FBA0 = 00A200AB
ati-GCKSMCIND-0003FBA4 = 0000000F
ati-GCKSMCIND-0003FBA8 = 0031002E
ati-GCKSMCIND-0003FBAC = 00330031
ati-GCKSMCIND-0003FBB0 = 002F002C
ati-GCKSMCIND-0003FBB4 = AF45793A
ati-GCKSMCIND-0003FBB8 = 3AC1D03E
ati-GCKSMCIND-0003FBBC = 324CF104
ati-GCKSMCIND-0003FBC0 = 467CDF3C
ati-GCKSMCIND-0003FBC4 = AC1F8FAC
ati-GCKSMCIND-0003FBC8 = 198626A2
ati-GCKSMCIND-0003FBCC = 2B183B0D
ati-GCKSMCIND-0003FBD0 = 32C6CD84
ati-GCKSMCIND-0003FBD4 = AE9FB85F
ati-GCKSMCIND-0003FBD8 = 40AA9E0B
ati-GCKSMCIND-0003FBDC = 7D4EEBA4
ati-GCKSMCIND-0003FBE0 = E4731308
ati-GCKSMCIND-0003FBE4 = 6B15E2FC
ati-GCKSMCIND-0003FBE8 = BCA8325B
ati-GCKSMCIND-0003FBEC = 9187AA15
ati-GCKSMCIND-0003FBF0 = E4233365
ati-GCKSMCIND-0003FBF4 = 820884D7
ati-GCKSMCIND-0003FBF8 = 82195BB4
ati-GCKSMCIND-0003FBFC = 1E1AE068
ati-GCKSMCIND-0003FC00 = 5FA03171
ati-GCKSMCIND-0003FC04 = A6BCF3A1
ati-GCKSMCIND-0003FC08 = 3252B2D5
ati-GCKSMCIND-0003FC0C = 526BDE47
ati-GCKSMCIND-0003FC10 = AE2D3C04
ati-GCKSMCIND-0003FC14 = A3E796B5
ati-GCKSMCIND-0003FC18 = 44AB920B
ati-GCKSMCIND-0003FC1C = F3BF902E
ati-GCKSMCIND-0003FC20 = 2570D927
ati-GCKSMCIND-0003FC24 = 41779375
ati-GCKSMCIND-0003FC28 = 7DA0F1D9
ati-GCKSMCIND-0003FC2C = F3CB1C1B
ati-GCKSMCIND-0003FC30 = 55692067
ati-GCKSMCIND-0003FC34 = C13FB81E
ati-GCKSMCIND-0003FC38 = F85F51C5
ati-GCKSMCIND-0003FC3C = 312E972A
ati-GCKSMCIND-0003FC40 = 70A30607
ati-GCKSMCIND-0003FC44 = 261A32A4
ati-GCKSMCIND-0003FC48 = CDE6740F
ati-GCKSMCIND-0003FC4C = FDD6B5CD
ati-GCKSMCIND-0003FC50 = BAEF6189
ati-GCKSMCIND-0003FC54 = 893CC8D2
ati-GCKSMCIND-0003FC58 = 6248483F
ati-GCKSMCIND-0003FC5C = 328F9036
ati-GCKSMCIND-0003FC60 = 15A417EA
ati-GCKSMCIND-0003FC64 = B5FD304D
ati-GCKSMCIND-0003FC68 = 8A82FF30
ati-GCKSMCIND-0003FC6C = 54EACF1D
ati-GCKSMCIND-0003FC70 = ABF59A9D
ati-GCKSMCIND-0003FC74 = E33E7FD0
ati-GCKSMCIND-0003FC78 = E7211FB9
ati-GCKSMCIND-0003FC7C = 10371337
ati-GCKSMCIND-0003FC80 = DEF2AD3C
ati-GCKSMCIND-0003FC84 = 342C50B7
ati-GCKSMCIND-0003FC88 = 3E241550
ati-GCKSMCIND-0003FC8C = C856B0A5
ati-GCKSMCIND-0003FC90 = EABB29DC
ati-GCKSMCIND-0003FC94 = 5C731A8B
ati-GCKSMCIND-0003FC98 = FD011797
ati-GCKSMCIND-0003FC9C = 4A1EEE1F
ati-GCKSMCIND-0003FCA0 = 66CFF5E3
ati-GCKSMCIND-0003FCA4 = 556934A8
ati-GCKSMCIND-0003FCA8 = 38BB9F55
ati-GCKSMCIND-0003FCAC = A9FED286
ati-GCKSMCIND-0003FCB0 = DC829672
ati-GCKSMCIND-0003FCB4 = 3894B8E6
ati-GCKSMCIND-0003FCB8 = A8578CD2
ati-GCKSMCIND-0003FCBC = 6683955E
ati-GCKSMCIND-0003FCC0 = 62E4755D
ati-GCKSMCIND-0003FCC4 = C9555632
ati-GCKSMCIND-0003FCC8 = 4EA1778D
ati-GCKSMCIND-0003FCCC = B18FD945
ati-GCKSMCIND-0003FCD0 = 52BA515F
ati-GCKSMCIND-0003FCD4 = ECBAC7B0
ati-GCKSMCIND-0003FCD8 = 158565C9
ati-GCKSMCIND-0003FCDC = 7CE8DE31
ati-GCKSMCIND-0003FCE0 = 80708866
ati-GCKSMCIND-0003FCE4 = 28C1BD42
ati-GCKSMCIND-0003FCE8 = B54299A8
ati-GCKSMCIND-0003FCEC = 5D208458
ati-GCKSMCIND-0003FCF0 = F2B7713D
ati-GCKSMCIND-0003FCF4 = E8A18821
ati-GCKSMCIND-0003FCF8 = C6A8427C
ati-GCKSMCIND-0003FCFC = B90C415D
ati-GCKSMCIND-0003FD00 = B88219D2
ati-GCKSMCIND-0003FD04 = 32D6A186
ati-GCKSMCIND-0003FD08 = 73D991E4
ati-GCKSMCIND-0003FD0C = 4778C5CB
ati-GCKSMCIND-0003FD10 = 113286F1
ati-GCKSMCIND-0003FD14 = 3C564749
ati-GCKSMCIND-0003FD18 = 36C91756
ati-GCKSMCIND-0003FD1C = 14E7E47B
ati-GCKSMCIND-0003FD20 = 93E82C0D
ati-GCKSMCIND-0003FD24 = B6B29F2A
ati-GCKSMCIND-0003FD28 = 7F99CF4D
ati-GCKSMCIND-0003FD2C = CB253B06
ati-GCKSMCIND-0003FD30 = 8DB6BB4F
ati-GCKSMCIND-0003FD34 = B7F4581E
ati-GCKSMCIND-0003FD38 = 0325B116
ati-GCKSMCIND-0003FD3C = 3A66833A
ati-GCKSMCIND-0003FD40 = 125AFF29
ati-GCKSMCIND-0003FD44 = 6C642036
ati-GCKSMCIND-0003FD48 = C42B087A
ati-GCKSMCIND-0003FD4C = 6BC422DD
ati-GCKSMCIND-0003FD50 = 27FEB995
ati-GCKSMCIND-0003FD54 = 05E0B25D
ati-GCKSMCIND-0003FD58 = DEF77276
ati-GCKSMCIND-0003FD5C = 1D0D1DB9
ati-GCKSMCIND-0003FD60 = 65678BB1
ati-GCKSMCIND-0003FD64 = F94BF677
ati-GCKSMCIND-0003FD68 = 93FDC93B
ati-GCKSMCIND-0003FD6C = 7EEBE1BF
ati-GCKSMCIND-0003FD70 = 27F37D4B
ati-GCKSMCIND-0003FD74 = 5ABAF1EC
ati-GCKSMCIND-0003FD78 = FEDFC1AB
ati-GCKSMCIND-0003FD7C = 2FBE3B3A
ati-GCKSMCIND-0003FD80 = 4536B1BD
ati-GCKSMCIND-0003FD84 = 5F11DCA9
ati-GCKSMCIND-0003FD88 = 37727D6E
ati-GCKSMCIND-0003FD8C = BBF5F52A
ati-GCKSMCIND-0003FD90 = 8A9DA6BA
ati-GCKSMCIND-0003FD94 = 25FAF749
ati-GCKSMCIND-0003FD98 = CEA4E2EF
ati-GCKSMCIND-0003FD9C = FB9E3694
ati-GCKSMCIND-0003FDA0 = CB1D04AD
ati-GCKSMCIND-0003FDA4 = 3B22E905
ati-GCKSMCIND-0003FDA8 = A6B4A9B4
ati-GCKSMCIND-0003FDAC = 9B9A5350
ati-GCKSMCIND-0003FDB0 = 0C61A976
ati-GCKSMCIND-0003FDB4 = B70B2078
ati-GCKSMCIND-0003FDB8 = 737DCA9F
ati-GCKSMCIND-0003FDBC = E0B72FEF
ati-GCKSMCIND-0003FDC0 = D7C3F598
ati-GCKSMCIND-0003FDC4 = DDD01F4D
ati-GCKSMCIND-0003FDC8 = BC45D9FC
ati-GCKSMCIND-0003FDCC = 5C0C9E63
ati-GCKSMCIND-0003FDD0 = DC919847
ati-GCKSMCIND-0003FDD4 = 29CD24F1
ati-GCKSMCIND-0003FDD8 = 8841C70F
ati-GCKSMCIND-0003FDDC = 6399CD0D
ati-GCKSMCIND-0003FDE0 = 4B37735B
ati-GCKSMCIND-0003FDE4 = F6FDF7AA
ati-GCKSMCIND-0003FDE8 = 7F5C9CDB
ati-GCKSMCIND-0003FDEC = B0D9F41D
ati-GCKSMCIND-0003FDF0 = 7B726B8E
ati-GCKSMCIND-0003FDF4 = FFA36335
ati-GCKSMCIND-0003FDF8 = C9B33ADC
ati-GCKSMCIND-0003FDFC = 1EE9EEE7
ati-GCKSMCIND-0003FE00 = 00005A00
ati-GCKSMCIND-0003FE04 = 000022A9
ati-GCKSMCIND-0003FE08 = 0000225C
ati-GCKSMCIND-0003FE0C = 007E8002
ati-GCKSMCIND-0003FE10 = 024518A2
ati-GCKSMCIND-0003FE14 = 00000012
ati-GCKSMCIND-0003FE18 = 3C000000
ati-GCKSMCIND-0003FE1C = 07020E40
ati-GCKSMCIND-0003FE20 = 001A013C
ati-GCKSMCIND-0003FE24 = 00000004
ati-GCKSMCIND-0003FE28 = 06FFA0EE
ati-GCKSMCIND-0003FE2C = 40300800
ati-GCKSMCIND-0003FE30 = 00006900
ati-GCKSMCIND-0003FE34 = 000022F6
ati-GCKSMCIND-0003FE38 = 00002300
ati-GCKSMCIND-0003FE3C = 00000000
ati-GCKSMCIND-0003FE40 = 00117EBE
ati-GCKSMCIND-0003FE44 = D61A07B9
ati-GCKSMCIND-0003FE48 = 00002C50
ati-GCKSMCIND-0003FE4C = 00000000
ati-GCKSMCIND-0003FE50 = 00000000
ati-GCKSMCIND-0003FE54 = 43414014
ati-GCKSMCIND-0003FE58 = 00000000
ati-GCKSMCIND-0003FE5C = 00000010
ati-GCKSMCIND-0003FE60 = 00000042
ati-GCKSMCIND-0003FE64 = 07E67DF0
ati-GCKSMCIND-0003FE68 = 00200020
ati-GCKSMCIND-0003FE6C = 000E0012
ati-GCKSMCIND-0003FE70 = 00000000
ati-GCKSMCIND-0003FE74 = 00000000
ati-GCKSMCIND-0003FE78 = 82D7CEED
ati-GCKSMCIND-0003FE7C = F34B6B4F
ati-GCKSMCIND-0003FE80 = BEEF5FA4
ati-GCKSMCIND-0003FE84 = E9FC4921
ati-GCKSMCIND-0003FE88 = 7FFEAA6E
ati-GCKSMCIND-0003FE8C = 00008400
ati-GCKSMCIND-0003FE90 = 0000097E
ati-GCKSMCIND-0003FE94 = 000009E2
ati-GCKSMCIND-0003FE98 = 89644656
ati-GCKSMCIND-0003FE9C = 9EE2CF81
ati-GCKSMCIND-0003FEA0 = 00000ACF
ati-GCKSMCIND-0003FEA4 = DCBEE259
ati-GCKSMCIND-0003FEA8 = 00008C00
ati-GCKSMCIND-0003FEAC = 000009E2
ati-GCKSMCIND-0003FEB0 = EFE333E9
ati-GCKSMCIND-0003FEB4 = CB228A7C
ati-GCKSMCIND-0003FEB8 = 479F6CFA
ati-GCKSMCIND-0003FEBC = DEFA9472
ati-GCKSMCIND-0003FEC0 = BF68F9AD
ati-GCKSMCIND-0003FEC4 = 00000D9B
ati-GCKSMCIND-0003FEC8 = 2BDB357E
ati-GCKSMCIND-0003FECC = 00000000
ati-GCKSMCIND-0003FED0 = 00000000
ati-GCKSMCIND-0003FED4 = 00000000
ati-GCKSMCIND-0003FED8 = 00000000
ati-GCKSMCIND-0003FEDC = 00000000
ati-GCKSMCIND-0003FEE0 = 00000000
ati-GCKSMCIND-0003FEE4 = 00000000
ati-GCKSMCIND-0003FEE8 = 00000000
ati-GCKSMCIND-0003FEEC = 00006400
ati-GCKSMCIND-0003FEF0 = 00000000
ati-GCKSMCIND-0003FEF4 = E5BEEF6C
ati-GCKSMCIND-0003FEF8 = 3EDF2D4D
ati-GCKSMCIND-0003FEFC = C2F023BF
ati-GCKSMCIND-0003FF00 = FCDA499F
ati-GCKSMCIND-0003FF04 = 8E6C6BE1
ati-GCKSMCIND-0003FF08 = 1B1F461E
ati-GCKSMCIND-0003FF0C = FF8D628D
ati-GCKSMCIND-0003FF10 = 8FFD8C92
ati-GCKSMCIND-0003FF14 = 00006400
ati-GCKSMCIND-0003FF18 = 00000000
ati-GCKSMCIND-0003FF1C = 00000000
ati-GCKSMCIND-0003FF20 = 00000000
ati-GCKSMCIND-0003FF24 = 00000000
ati-GCKSMCIND-0003FF28 = 00000000
ati-GCKSMCIND-0003FF2C = 00000000
ati-GCKSMCIND-0003FF30 = 00000000
ati-GCKSMCIND-0003FF34 = 000205F8
ati-GCKSMCIND-0003FF38 = 00000000
ati-GCKSMCIND-0003FF3C = 000124F8
ati-GCKSMCIND-0003FF40 = 0000E290
ati-GCKSMCIND-0003FF44 = 66EC7FBF
ati-GCKSMCIND-0003FF48 = C379DBD8
ati-GCKSMCIND-0003FF4C = 7ECB7FF7
ati-GCKSMCIND-0003FF50 = BE958E2F
ati-GCKSMCIND-0003FF54 = 00000266
ati-GCKSMCIND-0003FF58 = 2EBFD9F5
ati-GCKSMCIND-0003FF5C = 00000096
ati-GCKSMCIND-0003FF60 = 00000096
ati-GCKSMCIND-0003FF64 = 00000000
ati-GCKSMCIND-0003FF68 = 2E4F90FD
ati-GCKSMCIND-0003FF6C = 00000000
ati-GCKSMCIND-0003FF70 = 00000000
ati-GCKSMCIND-0003FF74 = 00008700
ati-GCKSMCIND-0003FF78 = 0000235C
ati-GCKSMCIND-0003FF7C = 000023C0
ati-GCKSMCIND-0003FF80 = 00000000
ati-GCKSMCIND-0003FF84 = 00000000
ati-GCKSMCIND-0003FF88 = 0000F61A
ati-GCKSMCIND-0003FF8C = 00006400
ati-GCKSMCIND-0003FF90 = 00000000
ati-GCKSMCIND-0003FF94 = 00000000
ati-GCKSMCIND-0003FF98 = 00000000
ati-GCKSMCIND-0003FF9C = 00000000
ati-GCKSMCIND-0003FFA0 = 00000000
ati-GCKSMCIND-0003FFA4 = 00000000
ati-GCKSMCIND-0003FFA8 = 00000000
ati-GCKSMCIND-0003FFAC = 00000000
ati-GCKSMCIND-0003FFB0 = 00000000
ati-GCKSMCIND-0003FFB4 = 00006400
ati-GCKSMCIND-0003FFB8 = 00000000
ati-GCKSMCIND-0003FFBC = 00030D40
ati-GCKSMCIND-0003FFC0 = 00000000
ati-GCKSMCIND-0003FFC4 = 00000000
ati-GCKSMCIND-0003FFC8 = 000008F0
ati-GCKSMCIND-0003FFCC = 00000000
ati-GCKSMCIND-0003FFD0 = 00000000
ati-GCKSMCIND-0003FFD4 = 00000000
ati-GCKSMCIND-0003FFD8 = 00000000
ati-GCKSMCIND-0003FFDC = 04000000
ati-GCKSMCIND-0003FFE0 = 00FF0000
ati-GCKSMCIND-0003FFE4 = 8FBEB2FF
ati-GCKSMCIND-0003FFE8 = 001E0500
ati-GCKSMCIND-0003FFEC = 002D100A
ati-GCKSMCIND-0003FFF0 = 00000000
ati-GCKSMCIND-0003FFF4 = 00000000
ati-GCKSMCIND-0003FFF8 = C0200000
ati-GCKSMCIND-0003FFFC = C0600000
ati-GCKSMCIND-C0100034 = 00AE399F
ati-GCKSMCIND-C0100038 = 0000C700
ati-GCKSMCIND-C0200000 = 00804603
ati-GCKSMCIND-C0200014 = 00C62200
ati-GCKSMCIND-C02000F0 = 00000000
ati-GCKSMCIND-C0200288 = 00000005
ati-GCKSMCIND-C020028C = 0149000B
ati-GCKSMCIND-C0200290 = 01F80000
ati-GCKSMCIND-C0200294 = 00006849
ati-GCKSMCIND-C0300008 = 00000000
ati-GCKSMCIND-C0300014 = 00004423
ati-GCKSMCIND-C0300018 = 0000002F
ati-GCKSMCIND-C0300068 = 40092587
ati-GCKSMCIND-C0300074 = 000EC815
ati-GCKSMCIND-C050002C = 00000001
ati-GCKSMCIND-C050008C = 0000000F
ati-GCKSMCIND-C05000B4 = 00000000
ati-GCKSMCIND-C05000B8 = 00321800
ati-GCKSMCIND-C05000CC = 0000000F
ati-GCKSMCIND-C0500120 = 0000000F
ati-GCKSMCIND-C0500140 = 00200005
ati-GCKSMCIND-C0500144 = 00000001
ati-GCKSMCIND-C0500148 = 10280000
ati-GCKSMCIND-C0500174 = 00240000
ati-GCKSMCIND-C05001A0 = 00000003
ati-GCKSMCIND-C05001D0 = 05E60BB8
ati-GCKSMCIND-C05001D4 = 00000000
ati-GCKSMCIND-C05001D8 = 00E829B8
ati-GCKSMCIND-C05001DC = 00E829B8
ati-GCKSMCIND-C05001E0 = 00E829B8
ati-GCKSMCIND-C05001E4 = 00E829B8
ati-GCKSMCIND-C05001E8 = 00000000
ati-GCKSMCIND-C05001EC = 00000000
ati-GCKSMCIND-C05001F0 = 00000000
ati-GCKSMCIND-C05001F4 = 00000000
ati-GCKSMCIND-C05001F8 = 00000000
ati-GCKSMCIND-C05001FC = 40040000
ati-GCKSMCIND-C0500200 = 00000009
ati-GCKSMCIND-C0500204 = 00003600
ati-GCKSMCIND-C0500208 = 00000000
ati-GCKSMCIND-C050020C = 00000000
ati-GCKSMCIND-C0500210 = 08000000
ati-GCKSMCIND-C0500214 = 64000000
ati-GCKSMCIND-C0500218 = 00000100
ati-GCKSMCIND-C050021C = 00400000
ati-GCKSMCIND-C0500220 = 00000000
ati-GCKSMCIND-C0500224 = 00000000
ati-GCKSMCIND-C0500228 = 00002011
ati-GCKSMCIND-C050022C = 00000000
ati-GCKSMCIND-C0500230 = 00000006
ati-GCKSMCIND-C0500234 = 00030041
ati-GCKSMCIND-C0500238 = 0032000F
ati-GCKSMCIND-C050023C = 0010000F
ati-GCKSMCIND-C0500240 = 00000000
ati-GCKSMCIND-C0500244 = 00000000
ati-GCKSMCIND-C0500248 = 40840000
ati-GCKSMCIND-C050024C = 00000019
ati-GCKSMCIND-C0500250 = 00000100
ati-GCKSMCIND-C0500254 = 00000000
ati-GCKSMCIND-C0500258 = 00000000
ati-GCKSMCIND-C050025C = 08000000
ati-GCKSMCIND-C0500260 = 64000080
ati-GCKSMCIND-C0500264 = 00000100
ati-GCKSMCIND-C0500268 = 00400000
ati-GCKSMCIND-C050026C = 00000000
ati-GCKSMCIND-C0500270 = 00000000
ati-GCKSMCIND-C0500274 = 00000000
ati-GCKSMCIND-C0500278 = 00035086
ati-GCKSMCIND-C050027C = 00030041
ati-GCKSMCIND-C0500280 = 0032000F
ati-GCKSMCIND-C0500284 = 0010000F
ati-GCKSMCIND-C0500288 = 00000000
ati-GCKSMCIND-C050028C = 00350A3D
ati-GCKSMCIND-C0500290 = 042A0400
ati-GCKSMCIND-C0500294 = 00000000
ati-GCKSMCIND-C0500298 = 02D3FFFF
ati-GCKSMCIND-C050029C = 00350A3D
ati-GCKSMCIND-C05002A0 = 062A000A
ati-GCKSMCIND-C05002A4 = 0034CC3C
ati-GCKSMCIND-C05002A8 = 02D3FFFF
ati-GCKSMCIND-C05002AC = 00000002
ati-GCKSMCIND-C05002B0 = 00000000
ati-GCKSMCIND-C05002B4 = 00000004
ati-GCKSMCIND-C05002B8 = 00000000
ati-GCKSMCIND-C05002BC = 00000000
ati-GCKSMCIND-C05002C0 = 00000000
ati-GCKSMCIND-C05002C4 = 40840000
ati-GCKSMCIND-C05002C8 = 00000019
ati-GCKSMCIND-C05002CC = 00003600
ati-GCKSMCIND-C05002D0 = 00000000
ati-GCKSMCIND-C05002D4 = 00000000
ati-GCKSMCIND-C05002D8 = 08000000
ati-GCKSMCIND-C05002DC = 64000080
ati-GCKSMCIND-C05002E0 = 00000100
ati-GCKSMCIND-C05002E4 = 00400000
ati-GCKSMCIND-C05002E8 = 00000000
ati-GCKSMCIND-C05002EC = 00000000
ati-GCKSMCIND-C05002F0 = 00000000
ati-GCKSMCIND-C05002F4 = 0003C085
ati-GCKSMCIND-C05002F8 = 00030041
ati-GCKSMCIND-C05002FC = 0032000F
ati-GCKSMCIND-C0500300 = 0010000F
ati-GCKSMCIND-C0500304 = 00000000
ati-GCKSMCIND-C0500308 = 001E0000
ati-GCKSMCIND-C050030C = 001E1000
ati-GCKSMCIND-C0500310 = 007684BD
ati-GCKSMCIND-C0500314 = 1000FFFF
ati-GCKSMCIND-C0500318 = 003C0000
ati-GCKSMCIND-C050031C = 041E1000
ati-GCKSMCIND-C0500320 = 007684BD
ati-GCKSMCIND-C0500324 = 1000FFFF
ati-GCKSMCIND-C0500328 = 00000003
ati-GCKSMCIND-C050032C = 00000000
ati-GCKSMCIND-C0500330 = 00000004
ati-GCKSMCIND-C0500334 = 00000000
ati-GCKSMCIND-C0500338 = 00000000
ati-GCKSMCIND-C050033C = 00000000
ati-GCKSMCIND-C0500340 = 00000000
ati-GCKSMCIND-C0500344 = 00000000
------[ PowerPlay BIOS Info ]------
Discussion Starter · #53 ·
Ok, you dumped the ATI/AMD registers but you need to dump the I2C/PMBus
A fish with teeth!
Ok yeah that's the right one. Still dunno how to find what I'm looking for tho.
------[ AIDA64 Extreme v5.90.4208 Beta ]------
------[ Microsoft Windows 7 Professional 6.1.7601.23807 Service Pack 1 (64-bit) ]------
------[ Video Adapters ]------
AMD Radeon RX 580 (Polaris 10) [1002-67DF / 1462-3418]
------[ Video Driver ]------
aticfx64||8.17.10.1534|||aticfx64||8.17.10.1534|||aticfx64||8.17.10.1534|||aticfx32||8.17.10.1534|||aticfx32||8.17.10.1534|||aticfx32||8.17.10.1534|||atiumd64||9.14.10.01261|||atidxx64||8.17.10.0733|||atidxx64||8.17.10.0733|||atiumdag||9.14.10.01261 - ATI Catalyst 15.8|||atidxx32||8.17.10.0733|||atidxx32||8.17.10.0733|||atiumdva||8.14.10.0582|||atiumd6a||8.14.10.0582|||atitmm64||6.14.11.25
------[ ATI I2C Device GPU #1 / B03-D37 ]------
  0000  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0010  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0020  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0030  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0040  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0050  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0060  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0070  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0080  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  0090  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  00A0  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  00B0  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  00C0  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  00D0  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  00E0  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
  00F0  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
------[ ATI I2C Device GPU #1 / B03-D3A ]------
  0000  A6 53 67 FC 20 00 00 00 B0 A2 CD 00 00 00 00 00  .Sg. ...........
  0010  96 3E 23 2C EA 00 00 00 74 37 55 4D 76 11 A9 38  .>#,....t7UMv..8
  0040  80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  33A6 3353 3367 33FC 3320 3300 3300 3300 33B0 33A2 33D5 3300 3300 3300 3300 3300
  0010  3396 333E 3323 332C 33EA 3300 3300 3300 3374 3337 3355 334D 3376 3311 33A9 3338
  0040  3380 3300 3310 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
------[ ATI I2C Device GPU #1 / B03-D50 ]------
  0000  00 FF FF FF FF FF FF 00 09 D1 D5 78 45 54 00 00  ...........xET..
  0010  23 18 01 03 80 3C 22 78 2E A5 95 A4 58 52 A0 26  #....<"x....XR.&
  0020  0D 50 54 A5 6B 80 81 80 81 C0 81 00 A9 C0 B3 00  .PT.k...........
  0030  D1 C0 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C  .......:[email protected],
  0040  45 00 56 50 21 00 00 1E 00 00 00 FF 00 57 38 45  E.VP!........W8E
  0050  30 34 39 35 30 30 31 39 0A 20 00 00 00 FD 00 32  04950019. .....2
  0060  4C 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC  L.S...      ....
  0070  00 42 65 6E 51 20 47 4C 32 37 36 30 0A 20 01 79  .BenQ GL2760. .y
  0080  02 03 22 F1 4F 90 1F 05 14 04 13 03 12 07 16 15  ..".O...........
  0090  01 06 11 02 23 09 07 07 83 01 00 00 65 03 0C 00  ....#.......e...
  00A0  10 00 02 3A 80 18 71 38 2D 40 58 2C 45 00 56 50  ...:[email protected],E.VP
  00B0  21 00 00 1F 01 1D 80 18 71 1C 16 20 58 2C 25 00  !.......q.. X,%.
  00C0  56 50 21 00 00 9F 01 1D 00 72 51 D0 1E 20 6E 28  VP!......rQ.. n(
  00D0  55 00 56 50 21 00 00 1E 8C 0A D0 8A 20 E0 2D 10  U.VP!....... .-.
  00E0  10 3E 96 00 56 50 21 00 00 18 00 00 00 00 00 00  .>..VP!.........
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47  ...............G
  0000  3300 33FF 33FF 33FF 33FF 33FF 33FF 3300 3309 33D1 33D5 3378 3345 3354 3300 3300
  0010  3323 3318 3301 3303 3380 333C 3322 3378 332E 33A5 3395 33A4 3358 3352 33A0 3326
  0020  330D 3350 3354 33A5 336B 3380 3381 3380 3381 33C0 3381 3300 33A9 33C0 33B3 3300
  0030  33D1 33C0 3301 3301 3301 3301 3302 333A 3380 3318 3371 3338 332D 3340 3358 332C
  0040  3345 3300 3356 3350 3321 3300 3300 331E 3300 3300 3300 33FF 3300 3357 3338 3345
  0050  3330 3334 3339 3335 3330 3330 3331 3339 330A 3320 3300 3300 3300 33FD 3300 3332
  0060  334C 331E 3353 3311 3300 330A 3320 3320 3320 3320 3320 3320 3300 3300 3300 33FC
  0070  3300 3342 3365 336E 3351 3320 3347 334C 3332 3337 3336 3330 330A 3320 3301 3379
  0080  3302 3303 3322 33F1 334F 3390 331F 3305 3314 3304 3313 3303 3312 3307 3316 3315
  0090  3301 3306 3311 3302 3323 3309 3307 3307 3383 3301 3300 3300 3365 3303 330C 3300
  00A0  3310 3300 3302 333A 3380 3318 3371 3338 332D 3340 3358 332C 3345 3300 3356 3350
  00B0  3321 3300 3300 331F 3301 331D 3380 3318 3371 331C 3316 3320 3358 332C 3325 3300
  00C0  3356 3350 3321 3300 3300 339F 3301 331D 3300 3372 3351 33D0 331E 3320 336E 3328
  00D0  3355 3300 3356 3350 3321 3300 3300 331E 338C 330A 33D0 338A 3320 33E0 332D 3310
  00E0  3310 333E 3396 3300 3356 3350 3321 3300 3300 3318 3300 3300 3300 3300 3300 3300
  00F0  3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3347
------[ ATI I2C Device GPU #1 / B05-D30 ]------
  0000  00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F  ................
  0010  10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F  ................
  0020  20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F   !"#$%&'()*+,-./
  0030  30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F  0123456789:;<=>?
  0040  40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F  @ABCDEFGHIJKLMNO
  0050  50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F  PQRSTUVWXYZ[\]^_
  0060  60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F  `abcdefghijklmno
  0070  70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F  pqrstuvwxyz{|}~
  0080  80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F  ................
  0090  90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F  ................
  00A0  A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF  ................
  00B0  B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF  ................
  00C0  C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF  ................
  00D0  D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF  ................
  00E0  E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF  ................
  00F0  F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF  ................
  0000  3300 3301 3302 3303 3304 3305 3306 3307 3308 3309 330A 330B 330C 330D 330E 330F
  0010  3310 3311 3312 3313 3314 3315 3316 3317 3318 3319 331A 331B 331C 331D 331E 331F
  0020  3320 3321 3322 3323 3324 3325 3326 3327 3328 3329 332A 332B 332C 332D 332E 332F
  0030  3330 3331 3332 3333 3334 3335 3336 3337 3338 3339 333A 333B 333C 333D 333E 333F
  0040  3340 3341 3342 3343 3344 3345 3346 3347 3348 3349 334A 334B 334C 334D 334E 334F
  0050  3350 3351 3352 3353 3354 3355 3356 3357 3358 3359 335A 335B 335C 335D 335E 335F
  0060  3360 3361 3362 3363 3364 3365 3366 3367 3368 3369 336A 336B 336C 336D 336E 336F
  0070  3370 3371 3372 3373 3374 3375 3376 3377 3378 3379 337A 337B 337C 337D 337E 337F
  0080  3380 3381 3382 3383 3384 3385 3386 3387 3388 3389 338A 338B 338C 338D 338E 338F
  0090  3390 3391 3392 3393 3394 3395 3396 3397 3398 3399 339A 339B 339C 339D 339E 339F
  00A0  33A0 33A1 33A2 33A3 33A4 33A5 33A6 33A7 33A8 33A9 33AA 33AB 33AC 33AD 33AE 33AF
  00B0  33B0 33B1 33B2 33B3 33B4 33B5 33B6 33B7 33B8 33B9 33BA 33BB 33BC 33BD 33BE 33BF
  00C0  33C0 33C1 33C2 33C3 33C4 33C5 33C6 33C7 33C8 33C9 33CA 33CB 33CC 33CD 33CE 33CF
  00D0  33D0 33D1 33D2 33D3 33D4 33D5 33D6 33D7 33D8 33D9 33DA 33DB 33DC 33DD 33DE 33DF
  00E0  33E0 33E1 33E2 33E3 33E4 33E5 33E6 33E7 33E8 33E9 33EA 33EB 33EC 33ED 33EE 33EF
  00F0  33F0 33F1 33F2 33F3 33F4 33F5 33F6 33F7 33F8 33F9 33FA 33FB 33FC 33FD 33FE 33FF
------[ ATI I2C Device GPU #1 / B05-D37 ]------
  0000  BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE  .n..n..n..n..n..
  0010  6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E  n..n..n..n..n..n
  0020  80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80  ..n..n..n..n..n.
  0030  BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE  .n..n..n..n..n..
  0040  6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E  n..n..n..n..n..n
  0050  80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80  ..n..n..n..n..n.
  0060  BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE  .n..n..n..n..n..
  0070  6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E  n..n..n..n..n..n
  0080  80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80  ..n..n..n..n..n.
  0090  BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE  .n..n..n..n..n..
  00A0  6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E  n..n..n..n..n..n
  00B0  80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80  ..n..n..n..n..n.
  00C0  BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE  .n..n..n..n..n..
  00D0  6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E  n..n..n..n..n..n
  00E0  80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80  ..n..n..n..n..n.
  00F0  BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE 6E 80 BE  .n..n..n..n..n..
  0000  336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E
  0010  3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380
  0020  33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE
  0030  336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E
  0040  3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380
  0050  33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE
  0060  336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E
  0070  3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380
  0080  33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE
  0090  336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E
  00A0  3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380
  00B0  33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE
  00C0  336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E
  00D0  3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380
  00E0  33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE
  00F0  336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E 3380 33BE 336E
------[ ATI I2C Device GPU #1 / B05-D3A ]------
  0000  52 47 9E 4B 53 00 00 00 C7 2B 47 00 00 00 00 00  RG.KS....+G.....
  0010  96 3E 23 2C EA 00 00 00 08 65 2F E0 17 E5 C0 88  .>#,.....e/.....
  0040  91 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  3352 3347 339E 334B 3353 3300 3300 3300 33C7 332B 3347 3300 3300 3300 3300 3300
  0010  3396 333E 3323 332C 33EA 3300 3300 3300 3308 3365 332F 33E0 3317 33E5 33C0 3388
  0040  3391 3300 3310 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300 3300
------[ ATI I2C Device GPU #1 / B06-D44 ]------
  0000  FF 00 00 00 00 00 00 00 00 66 66 66 00 00 00 00  .........fff....
  0010  00 00 88 88 88 66 66 66 44 44 44 00 00 00 73 80  .....fffDDD...s.
  0020  48 12 43 00 32 00 22 0F 04 45 05 5A 00 00 88 31  H.C.2."..E.Z...1
  0030  05 00 00 88 66 44 00 73 00 88 00 F8 0F 04 05 48  ....fD.s.......H
  0040  5A 44 00 00 00 00 00 70 70 03 29 00 00 00 FF FF  ZD.....pp.).....
  0050  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0060  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0070  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0080  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  00FF 0000 0000 0000 0000 0000 0000 0000 6600 6666 6666 0066 0000 0000 0000 0000
  0010  0000 8800 8888 8888 6688 6666 6666 4466 4444 4444 0044 0000 0000 7300 8073 4880
  0020  1048 4310 0043 3200 0032 2200 0F22 040F 4504 0545 5A05 005A 0000 8800 3188 0531
  0030  0005 0000 8800 6688 4466 0044 7300 0073 8800 0088 F800 0FF8 040F 0504 4805 5A48
  0040  445A 0044 0000 0000 0000 0000 7000 7070 0370 2903 0029 0000 0000 FF00 FFFF FFFF
  0050  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0060  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0070  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0080  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0090  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00A0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00C0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00D0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00E0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00F0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ Chips Found ]------
GPU1-B03-D3A: ***** Unknown Device *****
GPU1-B03-D50: EDID
GPU1-B05-D30: ***** Unknown Device *****
GPU1-B05-D3A: ***** Unknown Device *****
GPU1-B06-D44: ***** Unknown Device *****
Total   :   23.1 sec
GPU1-B00:    1.0 sec
GPU1-B01:    4.5 sec
GPU1-B02:    1.0 sec
GPU1-B03:    5.5 sec
GPU1-B04:    0.9 sec
GPU1-B05:    5.0 sec
GPU1-B06:    2.6 sec
GPU1-B07:    0.9 sec
Discussion Starter · #57 ·
This is a uP9505 due to register 0x49=03h (Version ID) and register 0x4A=29h (CHIP ID). Take a look at the the uP9505 spec pdf.
A fish with teeth!
A fish with teeth!
Awesome, thanks! So how do you know to look in the "B06-D44" section of the dump. Are you just looking for a section that has exactly 4A registers that aren't 00 or FF because you know that from the spec sheet info?
Also it seems I found the wrong sheet for the IR controller. It's only 2 pages and doesn't have an equivalent "SMBus Configuration Register" section.
How would I go about finding the correct spec sheets for the other 2 controllers?
41 - 60 of 80 Posts
