61 - 80 of 80 Posts
Discussion Starter · #61 ·
Well you look for the identification registers in the spec sheets and see if they match one of the i2c devices in the dump.
If you manage to find a spec sheet with all i2c registers of the IR controller please send it my way. AFAIK it is under NDA. The only thing you can find is a spec sheet that describes the PMBus of the IR controller.
Originally Posted by deeper-blue View Post
This is a uP9505 due to register 0x49=03h (Version ID) and register 0x4A=29h (CHIP ID). Take a look at the the uP9505 spec pdf.
Thank you, i've been able to id my vrm thanks to your post
Where can i find the pdf for uP9505 specs? I cant find it on google.
You need to work on your google skills - or should have looked just one page back in this thread
Thank you, again
So i tried to read and understand but looks a bit different than NCP80122 which i successfull undervolted, Do you know what register is the correct one for undervolt? The only registers i see that allow mV values are:
0x31=AVOFS0
0x32=AVOFS1
0x0C=VOFS0
0x0D=VOFS1
0x0E=VOFS2
0x0F=VOFS3
0x10=VOFS4
0x11=VOFS5
Discussion Starter · #66 ·
Originally Posted by rhaegon View Post
Thank you, again
0x31=AVOFS0
0x32=AVOFS1
0x0C=VOFS0
0x0D=VOFS1
0x0E=VOFS2
0x0F=VOFS3
0x10=VOFS4
0x11=VOFS5
Since I don't have a card with this controller I can't try and see if I'm correct but from the pdf I understand that you can set different voltage offsets for different voltage/load ranges. So depending on what you want to do either just try setting VOFS5 or give all states a different voltage offset. With VRMtool you can read/set the registers (but since it doesn't support the chip it won't do anything else so you have to observe the effect on the core voltage with a different tool).
I did a few I2C dumps with differents voltages
Stock I2C dump (Afterburner)
03 00 00 00 00 00 00 00 00 66 66 66 00 00 00 00
00 00 88 88 88 66 66 66 44 44 44 00 00 00 73 80
48 04 80 00 32 00 22 0F 04 05 05 5A 00 00 88 26 (80 = +0mV)
05 00 00 88 66 44 00 73 00 88 00 F8 0F 04 05 48
5A 44 00 00 00 00 00 70 70 02 29 00 00 00 FF FF
I2C dump with -25mV
48 04 84 00 32 00 22 0F 04 05 05 5A 00 00 88 26 (84 = -25mV)
I2C dump with -50mV
48 04 88 00 32 00 22 0F 04 05 05 5A 00 00 88 26 (88 = -50mV)
This does means that the register to modify is 0x32(AVOFS1)?
pd: i just notice that is 0x22 not 0x32 and according with spec sheet that just a ReadOnly field
Depends, do you see the core voltage adjusted by that amount while under load? (or in the scenario that you want the under voltage to be applied in)
Yes, but those results are modifying voltage with afterburner i did not actually modify any register yet by BIOS
Also the value 0x22 from I2C it just RO(ReadOnly) according to spec sheet (it says; 0x22 VDD voltage; Reading Voltage reading values in VFB [ 7 : 0 ] is from A/D result of actual output)
It makes sense. The VDD voltaje Reading is changing, so 0x22 shows that. You can't change the reading.
I think you still have to change one of the others offset that you mention earlier.
If i wanted to modify the registers, this should be done in the same way that i did for NCP80122?
My StockVOI:
34 00 03 01 01 07 0C 00 0E 00 00 00 00 00 00 00 04 00 24 00 00 04 00 00 02 80 10 00 00 00 00 00 20 03 00 00 10 00 52 03 02 00 00 00 84 03 02 00 10 00 B6 03
Should be:
46 00 03 01 01 03 12 00 10 96 20 00 00 00 00 00 0C 00 84 00 FF 00 01 07 0C 00 0E 00 00 00 00 00 00 00 04 00 24 00 00 04 00 00 02 80 10 00 00 00 00 00 20 03 00 00 10 00 52 03 02 00 00 00 84 03 02 00 10 00 B6 03
is that right?
My StockVOI:
Should be:
is that right?
Have you read this?
http://www.overclock.net/t/1621800/would-appreciate-help-in-finding-editing-the-voltage-offset-in-the-rx480-bios/150#post_26118389
I'm not sure about that 96 20.
Do you know the I2C adress? If its 20, i think you have to change to 96 40, if it's 25, 96 4A.
Originally Posted by elmanco View Post
Have you read this?
Nope, i dont know how to check the i2c address so i tried 96 20 and 96 40 with 0x31, 0x32 and 0C registers but voltage still the same.
edit: okay i think i found the i2c address in GPU1-B06-D44, so whats the value for 44?
Just guessing:
You have to write down both numbers in binary and add a 0 to the right.
So:
20 = 010 0000 + 0 = 0100 0000 = 40
25 = 010 0101 + 0 = 0100 1010 = 4A
44 = 100 0100 + 0 = 1000 1000 = 88
Again, just guessing.
Just guessing:
So:
Do you have the same I2C address in your card?
Hi guys I hope somebody can help me to clarify few things about this tool:
1-changes made with this tool are permanent?(I mean will still have an effect after a restart of the pc?). I f not, how can I make them permanent in the bios?
2-Is there any guide that explains how those settings affect efficiency,temps and power usage? I'm trying to make my R9 290 as efficient as possible, so that it use the least amount of power and run as cool as possible. Would anyone suggest me some changes that would increase efficiency/reduce power usage temperatures? I've already reduced gpu and aux voltages and frequencies.
Here's a ss of vrmtool running on my system. Any help would be appreciated.
My sapphire r9 290 has been downlocked to 850/1150 (947/1250 stock)and voltages reduced from 1.2v to 1.025v (and each other dpm state has been reduced roughly by -0.15v) and aux voltage has been reduced by -0.15v.
Discussion Starter · #78 ·
1) changes done to the VRM controller via I2C are only temporary - if you turn off the computer they reset. But if you change settings that are not reinitialized by the driver/gpu bios then they can survive a reboot - but not a power off. Look into the various other threads here about bios modifications. Basically you want to incorporate the commands send to the VRM controller via I2C into the voltage object info of the bios. Usually the bios already has some commands in there to set the defaults.
2) I'm not aware of any such guide. To get best efficiency you would probably have to learn a lot about VRM design, the VRM controller in question and the drivers/mosfets on your card. Load, cooling and specs all influence where the sweet spot might be. No simple way.
Why does this tool not work for my 280X with the IR3567B? Is there a way to make it work? Am I doing it wrong?
It starts out looking at the wrong I2C bus line number. And reports an "unknown" I2C device is present.
If I tell it the correct I2C bus line and device address, and ask it to read I2C device, it locks up trying to dump.
High IQ Person
Is there a way to set LLC via hex editor?
Edit: ops wrong thread
61 - 80 of 80 Posts
