Originally Posted by Afrodisiac
Amazingly, some people have things called budgets.
Amen! *raises hand*
I must say, the 4770 may be underrated. It performs quite well for me. I will eventually be splurging on a 5870, but for now, I am more than satisfied with what I have.
Originally Posted by dixson01974
Should of gone with HD4870 512mb or the 1gb depending on the games you play.
The HD4770 has alot more overclocking headroom then the HD4870 and taking into account that he probably bought it for less then £60 it's hands down the best choice for the price bracket, budget or not...
I want to overclock it but apparently VTX use different parts to due reduce costs and i was recommended not to overclock it cause the brand is unknown..
It's under warrenty with the retailer anyway so should i give it a go?
What's a good program to test artifacting? ATI Tool?
The PCB looks like a non-reference 4850..but mods are on the backside of the GPU. Looks like a swell power phase payout..should hold some good clocks and good voltage too. Is that the Voltera IC on the backside I can spot..or another?
*from the looks and the amount of capacitors on the PCB..I would say the card stands a chance to be a real good OC'r.
Overclock.net
