waht this mean?
619 11
Hey guys i had a big problem with CAT 9.2 , making my system unstable for some reason , but after i finish fixing the problem i tough that my windows was corrupted , so i did a fresh install and after finishing with the install this is what i got .
and the HDD is only 7 months old , i got it from the egg , should i start RMA process?
1 - 12 of 12 Posts
Looks like the HDD crashed. I would see if you can try to keep reproducing the problem and than do the same thing on a different HDD to see if it continues.
I also had one of my HDD 'fail' on me too. I spent 3 straight days testing the thing out. The actual problem was the SATA cable was loose. I would try that out too. Never know.
1 - 12 of 12 Posts
