1 - 3 of 3 Posts
Hi there,
last week I experienced a very-very annoying thing. I put the PC into sleep and as I wanted to wake it up nothing seemed to happen. After about 10 minutes win7 eventually loaded but it was incredibly slow. Then I tried to restart it - I couldn't. Not even the boot screen would show up. The reset button didn't work either and the leds on the mobo were constantly on.
I haven't seen anything like this before. What can cause such things? In the end, shaking the case turned out to be the remedy, ever since the PC has been working without troubles. Not being a techie I can only think of a loose connection - but where?
Any help would be greatly appreciated!
Best regards
Originally Posted by justarealguy View Post
Have you put the comp to sleep before? Your motherboard may not like suspended modes at all. I've had a few boards do this to me.
Hi,
thanks for your reply. I use sleep on a regular basis, never had such a problem before.
1 - 3 of 3 Posts
