Hello everyone.
new to this forum and new to watercooling, but have builded some pc's the last year's.
Now i want to try out watercooling, and have some questions i wonderd if anyone here could help me awnser.
Spec:
Mother: asus rampage 3 extreme
Cpu: intel i7 - 950
Vid: asus 580 gtx -2cards in SLI
case: cooler master - cosmos S
Rad: MagiCool Limited Edition "Monsta" 420/360 Triple 120mm / 140mm Xtreme Performance Radiator
pump: Swiftech MCP655™
vid blocks: EK waterblock, EK-FC5X0 GTX GW - EN (Nickel)
cpu block: EK CPU-waterblock, Supreme HF - EN Nickel
res: Koolance TNK-501 Reservoir
This is the parts i found out im going for to get a almost silent pc (reason for the big rad) so i can be able to clock without switching out many parts.
Now what "id" and "od" should i go when it comes to the tubing?
Will i be able to run this in one loop, res ->pump->gpu->gpu->cpu->rad->res or would i have to do it the other way around--
res ->pump->cpu->gpu->gpu->rad->res OR would i have to get 2 pumps?
im planing to have the rad on the inside TOP of the case, atleast thats the plan.
Would i have to get one more single rad, and have that between the cpu and the gpu's?
So far im staring to go over my budget but any tip will be taken with a smile.
Had to ship the rad back to get a new one as it got dmg in shipping:cryingsmi, so got some weeks befor i will build this in to my system, but would like to have everything sorted out so when the new rad comes i will be ready.
beforhand sorry for misstypes and what not, but im not to good in typing english, and i thank everyone that will give me tip's and advice.
Spec:
Cpu: intel i7 - 950
