Today I updated my Samsung 830 256GB's firmware. The update failed and I BSODed. Afterwards, the drive was no longer in BIOS. I talked to Samsung and they said that it is a common issue with the firmware update and the only solution is an RMA. Luckily I had a backup of everything as I always do.
So again, do not update the firmware on your Samsung 830, it may fail!
UPDATE: By disconnecting the drive and reconnecting it, it showed up in BIOS and booted normally. It also appears to be updated. No performance changes from before.
I talked to Samsung again, apparently I am the only one who has thus far reported it being fixed like this and they wanted my configuration. Considering others are getting it fixed, can you post your configuration such as Motherboard, OS, Other disks, etc. so that I can report it to them?
