1 - 20 of 33 Posts
Hi all, just thought I would post this as I just checked my Vertex drive life and was shocked to find only 37% remaining life when it was only bought in October.
I had followed all recommended tweaks including putting all temp folders for windows, IE, Chrome etc on a normal hdd, putting the swap on separate drive and pretty much switching it off, turning off indexing and defrag etc etc
I checked processes in Procmon after seeing this alarming figure and found out that Rainmeter writes small files constantly to both it's own install folder, as well as through appdata and also in other areas. I have now set all these access routes to dynamic links on a separate drive and hope that that will slow down the degradation.
Hope this is useful to people!
Reactions: ____
· Premium Member
What is the volume of writes by Rainmeter? I believe you can trace by process in the Windows Performance Monitor. (I'm on XP at work so I can't verify.)
Software tools reading "remaining life" are inaccurate.
Well write endurance on the original vertex cells is 5000 PE and the current average is between 3 and 4k writes.
Rainmeter writes many tiny files a second avg between 1 and 8 (length) in Disk Monitor
· I'm gonna need a sweeper
Going by Windows, Rainmeter never really writes to my drive. Only does if I close and re open it.
It seems to concentrate most of it's file creation and deletion on weather and temp apps, if you are not using those it might not be causing as much of an issue
I only use a clock and one for Winamp. That said I doubt Rainmeter uses the drive more than Windows does just running so I cant see how that could kill a drive very quickly.
· Premium Member
Can you point it to a RAMDisk?
Sounds like bad coding.... programs should not be do read/writes that often if they can help it....
· Super Moderator
I have extreme doubts that it's Rainmeter that's sucked the health out of the drive. Back when my Falcon worked (it's sort of a Vertex clone, though I have the 64GB version) I was using Rainmeter for most of its life (which was more than a year), and its health never went below 80-90%.
Discussion Starter · #9 ·
It's the only thing in my Procmon that did any amount of writing to my ssd; windows writes a minuscule amount in comparison and all the tiny writes seem to have been chewing through the PE count; All windows temps are linked to my E drive so only windows write is the odd explorer one really.
You'll have to help me on that one, never used a ramdisk
Discussion Starter · #11 ·
Did you use the Dark Rainmeter weather skin? 99% of rainmeters writes and erases are to and from that skin in my processes here.
· Super Moderator
Yes, as well as HUD.Vision and Enigma, though the latter's a stock skin IIRC.
Discussion Starter · #13 ·
Here's a tiny snapshot of a few miliseconds of write activity from Rainmeter, which was previously going to C:\
Mostly it's from the system temp and weather skins and they are really tiny writes, loads per second
· Premium Member
With that much action by a Rainmeter app, was there not much of a overall pc performance change? I imagine it must have been hogging some cpu usage.
· Programmer
How did you even check the life of your SSD?
Discussion Starter · #17 ·
No CPU useage really noticed, Idles at 1 to 2% with rainmeter running, no performance decrease to suggest anything funky was going on
Discussion Starter · #18 ·
Originally Posted by MechanicalHand;13100761
what did you use to check this?
The writes or the life?
The writes I used Procmon and Diskmon from Sysinternals Suite (free dl from MS)
Drive life is checked via smartctl which gives raw Data and life in percentage
· Premium Member
If it logging data and such, it barely hits the CPU.
Discussion Starter · #20 ·
1 - 20 of 33 Posts
