1 - 8 of 8 Posts
The new Nvidia drivers, the 93.71 are corrupt. When installed they disable sli and reconfigured GDDR3 cards to show say the speed 550/1500 it will be 500/3000 which will corrupt riva tuner settings etc. or make your computer. constantly restart.
I've just installed the new drivers, and I dont have any problems at all...
No restarts or anything...
But yes, it shows 1.5GHz memory speed... But whats the problem with that?
My old 6800Ultra showed it in x2 value too...
Since it's DDR, I guess its effective clock speed is 750mhz.. so if it showed a DDR speed of 3000mhz, it would be constantly clocked at 1500mhz.. which would, of course, bugger it up..
Originally Posted by bdattilo
All works for me. Is it just a 6 series error?
It might be... (I dont use the 6800Ultra anymore, bought a new comp with 7950GT)
But now my 7950GT shows 602/1500MHz (overclocked)
*Coolbits*
i dont have any problems with the drivers
1 - 8 of 8 Posts
