Wat PSU should i get?
494 Views 8 Replies 8 Participants Last post by  crashnburn_819
i recently blew out my video card cause i bought a cheap PSU, anyone have suggestions on wat type of PSU i should get now so i dont make the same mistake? http://www.newegg.com/Product/Produc...82E16814102810 that is my video card
1 - 9 of 9 Posts
Seconded to the 650tx especially you have a quad cpu. 4870 is a 150w GPU.
Always go with the a quality power supply when powering something you sank a lot of money into. I would recommend, Corsair, Antec, Seasonic, PC Power & cooling. They all make quality products that can be trusted. It all depends on the hardware you are running and the money you want to spend, but remember the power supply is the backbone of your computer.
I recommend:
enermax
seasonic
ANTEC
PCPOWERANDCOOLING
CORSAIR
bfg
ocz
thermaltake
coolmaxgreenpower ONLY
COOLERMASTER
tuniq
rosewill
ultra
Corsair HX 620 sounds good. If you need more juice take a look a the 750TX and 850TX.
same as juggalos advice. i have the corsair 750tx and it has enough power for 2 of your cards.
1 - 9 of 9 Posts
