Water block
660 Views 2 Replies 2 Participants Last post by  Bullant
Hi all,
I,ve just bought the new Evga classified 4 way mother board and was wondering,will the motherboard water block make much difference.Or is there really no need for it.It cools the NB and SB.
1 - 3 of 3 Posts
I remember seeing a roundup of 3 different waterblocks for the classified's north and south bridge, but i cant seem to find it anymore. But putting the chipset on water vs stock passive cooling showed huge improvments in temps, and water vs stock active cooling showed a noticable improvment.
Pros: putting it on water will help keep your case ambient temps down, and cooler electronics use less voltage.
Cons: will probably cost over $100 just for the block and will only get you about 50mhz more on your cpu oc, if you're lucky.
Verdict: If you dont minding spending the money, go for it! It'll look great and prolong the life of the mobo!
Thanks for the reply
1 - 3 of 3 Posts
