Hello people,
I am building a comp when I get back home and I really want to make a custom water cooling set up for my future rig seeing how I can't find a set up to do what I want. I just wanted the experienced people out there to help me in deciding if these parts are good for it and if not what would be some changes you would make. I will be using non-Conductive water coolant. The WB's will be for an AMD 2+ 4870 x2 build. All of the fittings for the equipment listed is rated for 1/2 ID tubing. If any one out there has a water cooled 4870 x2 please let me know what would be good to cool the mem modules.
Hydor L30 in-line 320 GHP pump
2 Black Ice 120mm radiators
D- Tec Fuzion v2 CPU water block for the Phenom 9950 Black Edition
2 Swiftec MCW60-R2 VGA water block for the 4870 x2
Danger Den 32 ounce 5.25 double bay reservior
250mm Cooling fan
This is what I will use as far as product wise. When I get home I will build the custom set up which all of it will be external except for the WB's and some tubing of course. I will take picture of the future build and post it for you AMD loyals to see. I do not want to spend more that $450 for the set up
250mm Cooling fan
