1 - 20 of 24 Posts
Ok, so i've been thinking of going back to the watery side (muahahahaha), but i've been away from it for a while now, and i feel alittle out of the loop (no pun intended). <br />
<br />
SO, what are the best i can get, keeping total cost around 200 (i want it to cool my cpu primarily, possibly my chipset but it would need to be and EXTREMELY low profile water block, because of my video card):<br />
<br />
CPU block: <a href="http://xoxide.com/swiftech-apogee-water-block.html" target="_blank">http://xoxide.com/swiftech-apogee-water-block.html</a><br />
12V pump (with standard molex): <a href="http://xoxide.com/swiftech-mcp355-pump.html" target="_blank">http://xoxide.com/swiftech-mcp355-pump.html</a><br />
really good 2x120mm heatercore: <a href="http://www.dangerdenstore.com/product.php?productid=2&cat=85&page=1" target="_blank">http://www.dangerdenstore.com/produc...&cat=85&page=1</a><br />
2 fairly silent 120 fans:<br />
coolant:<br />
reservoir: <a href="http://xoxide.com/thermaltake-aquabay-m3-reservoir.html" target="_blank">http://xoxide.com/thermaltake-aquabay-m3-reservoir.html</a><br />
<br />
<br />
links are optional, but highly appreciated <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" />
You might be able to use this for the cpu...Research it and make sure......... <a href="http://www.svc.com/apogee-1user.html" target="_blank">Swiftech Apogee-1U Server High Performance Waterblock for AMD and Intel Servers (3/8" and 1/2" barbs) (Out of Stock)</a><br />
<br />
Pump Laing D-5.... <a href="http://www.dangerdenstore.com/product.php?productid=175&cat=23&page=1" target="_blank">Danger Den :: Pumps :: DC Powered :: 12V DD-D5 Pump</a><br />
<br />
.EDIT: Heres a good heatercore. <a href="http://www.dangerdenstore.com/product.php?productid=48&cat=14&page=1" target="_blank">Danger Den :: Radiators :: Heater Core Radiators :: Double Heater Core with Fittings</a> Here is a new rad that is killing the BIX, really<a href="http://www.dangerdenstore.com/product.php?productid=256&cat=90&page=1" target="_blank">Danger Den :: Radiators :: Black Ice Series :: GTX Xtreme Series </a><br />
HW Lab's link.......<a href="http://www.hwlabs.com/gen2/gtx/gtx240.htm" target="_blank">:::: Hardware Labs - Gen Two ::::</a><br />
<br />
These are great to and cheaper........ <a href="http://www.dangerdenstore.com/product.php?productid=221&cat=86&page=1" target="_blank">Danger Den :: Radiators :: Black Ice Series :: GTS Stealth Radiator :: Stealth GTS 240 Black Ice</a><br />
<br />
I use this for fluid it comes in other colors to...... <a href="http://www.svc.com/fxphpmb32.html" target="_blank">Fluid XP+ HP High Performance Non-Conductive Coolant - UV Midnight Blue 32oz.</a><br />
<br />
I use this res.......<a href="http://www.dangerdenstore.com/product.php?productid=52&cat=27&page=1" target="_blank">Danger Den :: Reservoirs :: Bay Style Reservoirs :: Danger Den Single 5 1/4" Bay Reservoir</a>
Welcome back! <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <br />
<br />
My opinion for a killer loop:<br />
Swiftech <a href="http://www.frozencpu.com/products/2033/ex-blc-244/Swiftech_APOGEE_Extreme_Performance_Universal_CPU_Waterblock.html?tl=g30c85s141" target="_blank">Apogee</a> CPU block - $50<br />
Swiftech <a href="http://www.petrastechshop.com/laddcwpeddto.html" target="_blank">MCP355</a> w/ Petratech Top - $99 - Expensive, but the best there is<br />
Black Ice <a href="http://www.dangerdenstore.com/product.php?productid=221&cat=86&page=1" target="_blank">GTS</a> or <a href="http://www.dangerdenstore.com/product.php?productid=2&cat=85&page=1" target="_blank">Xtreme</a> 240 Radiator - $45<br />
Aerocool <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835129246" target="_blank">Xtreme</a> Turbine Fans - 32db 90CFM - $11 each (x2)<br />
Coolant - Just use some distilled water mixed with a little anti-freeze - $1<br />
<br />
Total: $217<br />
You'll still need some tubing but that wouldn't be more than $10<br />
<br />
<br />
If $200 is a hard budget cap, switch the pump to a <a href="http://www.dangerdenstore.com/product.php?productid=175&cat=23&page=1" target="_blank">D5</a> Not quite as good but still revered by many as the one of the best water cooling pumps available.<br />
<br />
<br />
Hope that helps
Discussion Starter #4
wat i meant by lowprofile CHIPSET, is that the barbs will have to stick out from the side, as opposed to on top, i think just about anything where the barbs are centered will not work
Ah, you beat me Ira, and put up a nearly identical list!
<tr>
<div>
Originally Posted by <strong>JBD1986</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385685#post1385685" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">wat i meant by lowprofile CHIPSET, is that the barbs will have to stick out from the side, as opposed to on top, i think just about anything where the barbs are centered will not work</div>
</td>
</tr>
</table>
</div> Do you think this one with a off-set would work?... <a href="http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=241&products_id=4527&zenid=20791a9c7bea2105a82b8e84f1c40129" target="_blank">Alphacool NexXxoS NB-SLI 1 Northbridge Products Model: 12335 [12335] : Performance-PCs.com, ... sleeve it and they will come</a>
Discussion Starter #7
I like these so far:<br />
<br />
<br />
<br />
Discussion Starter #8
<tr>
<div>
Originally Posted by <strong>ira-k</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385698#post1385698" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Do you think this one with a off-set would work?... <a href="http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=241&products_id=4527&zenid=20791a9c7bea2105a82b8e84f1c40129" target="_blank">Alphacool NexXxoS NB-SLI 1 Northbridge Products Model: 12335 [12335] : Performance-PCs.com, ... sleeve it and they will come</a></div>
</td>
</tr>
</table>
</div>thats wat had in mind, but i cant tell how high it goes in the center, 24mm is the hight of the barb section, i need the height of the lower section<br />
<br />
if i had to guess, id say i have about 10mm of clearance under my video card
<tr>
<div>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385716#post1385716" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">thats wat had in mind, but i cant tell how high it goes in the center, 24mm is the hight of the barb section, i need the height of the lower section<br />
<br />
if i had to guess, id say i have about 10mm of clearance under my video card</div>
</td>
</tr>
</table>
</div> I'll look some more....Hey Snerp is selling some of his stuff.He has a nice Koolance rig...<a href="http://www.overclock.net/sale/128070-sale-most-snerps-rig-other-goodies.html" target="_blank">For Sale: Most of Snerp's Rig and Other Goodies! - Overclock.net - Overclocking.net</a>
It looks like it's 14mm...Check it out measure again and see ....<a href="http://www.alphacool.de/product_info.php/products_id/3546/cPath/5_18_21/chipset-water-coolers/wak-mb-alphacool-nexxxos-nb-sli-1-northbridge.html" target="_blank">Alphacool GmbH - The Cooling Company - WAK MB Alphacool NexXxoS NB-SLI 1 Northbridge 12335</a>
Discussion Starter #11
<tr>
<div>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385776#post1385776" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">It looks like it's 14mm...Check it out measure again and see ....<a href="http://www.alphacool.de/product_info.php/products_id/3546/cPath/5_18_21/chipset-water-coolers/wak-mb-alphacool-nexxxos-nb-sli-1-northbridge.html" target="_blank">Alphacool GmbH - The Cooling Company - WAK MB Alphacool NexXxoS NB-SLI 1 Northbridge 12335</a></div>
</td>
</tr>
</table>
</div>it's questionable...<br />
but in one of those pics, it looks similar to my scenario, with the vid card overhang (... wat a crappy design btw)
<tr>
<div>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385823#post1385823" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">it's questionable...</div>
</td>
</tr>
</table>
</div> OK, I'll see if I can find another one....<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I'll have to find the height spec's but this is the style you need.<b>EDIT:</b>I went to there web-site and all it say's are they are 18-25mm high with the straight barb...I dont know this is the type you need with the side barbs, take a look and see.. <a href="http://www.aqua-computer.de/e_index.htm" target="_blank">aqua-computer - watercooling systems for your pc</a> ..Never even knew they made a side mount like this....<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />....<a href="http://www.sharkacomputers.com/aqcotwwablwp.html" target="_blank">Aqua Computer Twinplex</a>
Discussion Starter #14
the northbridge is really just an afterthought at this point<br />
<br />
i need to get everything down for the main loop first and see wat the expense will be
<tr>
<div>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385867#post1385867" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">the northbridge is really just an afterthought at this point<br />
<br />
i need to get everything down for the main loop first and see wat the expense will be</div>
</td>
</tr>
</table>
</div> Yeah you dont even really need to WC the NB...A good fan on it should be enough.....Are you wanting 3/8 or 1/2 for it? I would go with 1/2 fitting and use the 7/16 Masterkleer on it...Easier to work with and almost as good flow....The T-Take res will kill your flow, it's restrictive...I would go with the DD bay res....I know it ain't as sexy looking though...<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
for the chipset cooling heres ur best bet on ur dfi.<br />
<br />
1. dont w/c ur chipset stupid/waste of time. get an Evercool VC-RE on it (-10 more)<br />
<br />
2. Get an MAZE4-GPU on that X1900XT instead.
Discussion Starter #17
well the problem is, i had to pop off the fan on my dfi nb chip for my vcard to fit in there, so right now, all there is a metal plate with outer fins only.<br />
<br />
im thinking of this:<br />
<u><font color="#22229c"><a href="http://www.jab-tech.com/Evercool-VC-RF-pr-3229.html" target="_blank">http://www.jab-tech.com/Evercool-VC-RF-pr-3229.html</a></font></u>
<tr>
<div>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385925#post1385925" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">well the problem is, i had to pop off the fan on my dfi nb chip for my vcard to fit in there, so right now, all there is a metal plate with outer fins only.<br />
<br />
<u><font color="#22229c"><a href="http://www.jab-tech.com/Evercool-VC-RF-pr-3229.html" target="_blank">http://www.jab-tech.com/Evercool-VC-RF-pr-3229.html</a></font></u></div>
</td>
</tr>
</table>
</div> <br />
That should work fine...
SNERP!!!
<a href="http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=197&products_id=4638" target="_blank">http://www.performance-pcs.com/catal...oducts_id=4638</a><br />
<br />
-19C on my NB <b>without</b> using the fan. Expensive? You bet! Worth it? Damn right!
Discussion Starter #20
<tr>
<div>
Originally Posted by <strong>Snerp</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1385944#post1385944" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic"><a href="http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=197&products_id=4638" target="_blank">http://www.performance-pcs.com/catal...oducts_id=4638</a><br />
<br />
-19C on my NB <b>without</b> using the fan. Expensive? You bet! Worth it? Damn right!</div>
</td>
</tr>
</table>
</div>wow that's nice, you have basically the same board. Did u have a similar problem, and will that heatsink touch my cpu heatsink?
1 - 20 of 24 Posts
