For the pump, the mcp655 is an awesome pump, the D-tek fuzion is really good and the res you picked is nice too. For the fluid, I personally like using Petra PT Nuke with distilled water, most people like that stuff. The Yate Loons are awesome fans as well.
The draining process is a matter of preference. I hate t-lines because getting rid of air is so annoying with them. What I do for draining is make the res removable, then suck the fluid out with a squirtbottle, then disconnect one of the tubes from the res and let it drain out into a bottle or something. It works great, you just gotta be careful.
Good luck with your build!
