1 - 15 of 15 Posts
Hello guys, need help with one of my setup. Due to the length of the acrylic tube, i have to have one inlet at the top of the reservior. My setup is almost the same as his. Was wondering if there will be any issue. If i am not wrong, if i turn off the machine, the water from the top tubings might flow back into the reservior resulting in some empty tube in the loop. Consulted the local shop but they claim that as soon as you turn the machine back on, the loop will work as normal again without any bleeding problems. Is this the case ?
Thanks in advance.
Originally Posted by SpykeZ View Post
You shouldn't have any open tubing. Run the pump until it gets the water going, add more water, rinse and repeat until the system is full.
Hi Spykez, thanks for the reply. What i meant was after this step, when the loop is clear of air bubbles and when the loop is full. Should i turn off the pump , will some water from the inlet flow back to the reservior?
I've no idea what I'm doi
Once the loop is full, with all the bubbles cleared out, it won't matter where the water flows once the pump shuts off. Once you turn it back on it will go where it has to go.
Ya I got that, what it makes it sound like you're saying is there's still enough room for water to flow into an empty spot. It should be full to the point where it doesn't matter.
When the pump shuts off the water might still move a little bit just from the flow but it'll slow down and the water will stay put.
Basically this. It will only matter if you still have air bubbles in your loop.
Might want to change your front fans to intake rather than exhaust.
Discussion Starter #9
Ah that is what i wanna confirm. Thanks mate !!!
Discussion Starter #10
yup it is on intake. This is not my built. My built is quite similar in term of layout. Thanks for the heads up
Discussion Starter #11
Hmm thanks for the confirmation. Sorry my english was bad. Ha
Just a tip for ya since you're new, see that multi button on the bottom right of posts? If you click the multi button on every post you want to quote, then hit the reply button on the last post, it'll open up your reply post with all the quotes you wanted to answer for a single post
Discussion Starter #13
Oh... thanks lol
1 - 15 of 15 Posts
