Hi OCN
OK for my up coming build when the intel haswell and the new gtx 700 series come out, I will be doing a fully water cooled build and I need you guys to have a look at some of the things I have chosen, please ask questions so I can clarify something for you, or give any other recommendations you can to me
WHAT I THINK I WILL BE GETTING SO FAR:
CPU block http://www.jab-tech.com/EK-Supremacy-CPU-Water-Block-Nickel-Plexi-pr-5005.html
GPU block - some new block
PUMP - http://www.jab-tech.com/Swiftech-MCP-355-12v-DC-Pump-pr-3510.html
RADS - x2 http://www.jab-tech.com/Black-Ice-GT-stealth-240-Black-pr-3417.html
RES - http://www.jab-tech.com/Swiftech-MCP35X-Reservoir-Rev-2b-pr-4810.html
FITTINGS- http://www.jab-tech.com/Enzotechnology-Compression-Fitting-1-2-3-4-Matt-Black-pr-4686.html
Please check these parts out and recommend also what tubing should I get because I really have no clue
THANK you very much rep to all who help
